    Vismat materials sketchup+vray
    renderpluginsextensions
    2 Posts 2 Posters 1.8k Views 2 Watching
      callinas
      Hi, have some pack textures like stone wall or stone pavement. I use metric units. When applying the texture it is or so big or so small. For example a pavement with 11 X 11 cm granite stones, when applied the texture it is so small.
      So, where can change the scale or size or dimension of a texture,,,?
      • Lampe au Néon Pelle à TarteL Offline
        Hello. I am a beginner, so please be indulgent if my answer lacks pertinence. I have met the same issue lately. I had to discover myself how to resolve it since in here, it seems the simpler and more basic the question, the rarer the answer. I respect that, as it reminds me Spinoza's "narcissism of small differences" concept. (damn, who the heck do I think I am ?!)
        Try this as a temporary, yet could work solution:
        select your material in the Vray material editor
        click on the blue M in the "Diffuse" area
        make sure the file you have selected in top is the one that came with your vismat. If not, browse and select it.(has a _d, or diff at end)
        type OK to come back to the Vray material editor window.
        By this time, you should notice that your material appears visually as such in your model.
        Select it and scale it in the material window of sketchup.
        Now, if you find how to make the pattern to start from a precise point (usefull for a glass blocks door for instance) please let me know.
        Bon courage.
        NPAT
