    [REQUEST] Toggle snap
    6 Posts 5 Posters 656 Views 5 Watching
    • silvershadowS Offline
      silvershadow
      Hi guys, I am looking for a plugin that one can switch off x/y/z access snap on the go and where this can be programmed to a shortcut button. Its really annoying when drawing a line and it keeps following a line with the access and am forced to manually set a new xyz so that this wont follow it. (where in some cases it just reset itself while working)
      I want to toggle this to only snap to points / line edges with a command.
      • BoxB Offline
        Have you tried turning snapping off or adjusting the precision of your units.
          silvershadow
          yes this is not the case.
          I know how to set all of this..
          but in this case.. i dont want it to follow any xyz line. I only want this in a button so that i can switch this off and the only remaining snapping left is point and line snapping. I do not want the snapping to be turned off on geometry. It seems like a stupid request but it will be really helpful where im working on at the moment since it has a lot of non even geometry
            Moving or drawing on axis is part of Inferencing so you want to turn that off. As I understand it, this is not possible.
            • DETXD Offline
              DETX
              It is good if SU has Snap Tools like Auto CAD or any CAD Software.
              • panixiaP Offline
                panixia
                oh my god.. honestly i think not really a good idea.. that wouldn't be sketchup anymore imho.. πŸ˜„
