    Delete all layers via ruby
    6 Posts 3 Posters 1.1k Views 3 Watching
    • CadFatherC
      CadFather
      does anyone know if this is possible: delete ALL existing model layers and put all geometry on layer 0?
      i looked around in the forum and in the api, but only found a way to remove a layer by name or index (only for 2015).
      i'm trying to integrate it in a batch process
      • S
        slbaumgartner
        Probably the easiest way would be to iterate through all the geometry in the model and assign layer0 to everything, then invoke Sketchup.active_model.layers.purge_unused.
        • CadFatherC
          CadFather
          yes, i did that, it worked until i got stuck trying to dig through groups and components...
          • TIGT
            m=Sketchup.active_model; m.start_operation('!'); m.entities.each{|e|e.layer=nil}; m.definitions.each{|d|d.entities.each{|e|e.layer=nil}}; m.layers.purge_unused; m.commit_operation
            Reassigns everything [including things inside defiintions etc] to use 'Layer0', then purges all unused layers [i.e. all layers except 'Layer0']. It is one step undo-able.
            • CadFatherC
              CadFather
              Thanks TIG, you are the best! πŸ˜„ πŸ‘
              so you are mining for entities (including groups i presume), AND component definitions...
              • TIGT
                Yes everything.
                All entities in all entities-collections.
