    Drawing with GL
    24 Posts 4 Posters 1.7k Views 4 Watching
    • CadFatherC Offline
      CadFather
      isn't this supposed to work? ( knowing my coding genius probably not.. πŸ˜’ )
      i thought i cracked it but i get: #Sketchup::View:0x00000007665b00 and nothing drawn
      @p1=200,200,0
      @p2=600,600,0
      model=Sketchup.active_model
      view=model.active_view
      view.line_width=10
      view.draw2d GL_LINES, [@p1, @p2]
        driven
        This method can only be called from within the draw method of a tool that you implement in Ruby.
        the bolding is mine, the rest from the API...
        well known gotcha, so don't fell too bad...
        there is a simple tool with the method, somewhere [here] >> http://sketchucation.com/forums/viewtopic.php?p=245880#p245880
        john
          CadFather
          John, Thanks for this.
          i actually did try it wrapped up in a class method, and called it from the
          Sketchup.active_model.select_tool Gridz.new
          still had no result. at least i now know where not to look! πŸ‘
            CadFather
            that was good (if only from a neurological perspective), seems like what i missed was 'onMouseMove invalidate' (thanks to the Chris F example you linked). however the line disappears when orbiting - even if i use the invalidate on onMButtonDown. πŸ˜’
            require 'sketchup.rb'
            class Layz
            	def activate
            			@p1=200,200,0
            			@p2=600,600,0
            	def onMouseMove(flags, x, y, view)
            			view.invalidate
            	def draw(view)
            			model = Sketchup.active_model
            			view = model.active_view
            			view.line_width = 10
            			view.drawing_color = "red"
            	end   #def
            end # class
            if !file_loaded?(File.basename(__FILE__))
            UI.menu("Plugins").add_item('Layz'){ Sketchup.active_model.select_tool Layz.new }
              driven
              @cadfather said:
              ...however the line disappears when orbiting -
              even fredo's toolbars disappear when you orbit...
              I think SU suspends the GL drawn elements to help cope with showing the model...
              john
                CadFather
                ..makes sense, though when i look at those aspect ratio bars on the sides (like advanced camera tools), they do stay on screen.
                  driven
                  they are completely controlled by SU so I guess they has that option...
                  but not us...
                  EDIT: watermarks will also stay put, they may be using those...
                  john
                    CadFather
                    mmm maybe so, advanced camera tools is a ruby script though.
                    unfortunately it's flipping scrambled πŸ˜’
                      When you orbit the Orbit tool is pushed into the tool stack - suspending your tool. So you have to invalidate the view in the resume event. You also want to invalidate the view on deactivate as otherwise your drawing might stick around after your tool is not active any more.
                        CadFather
                        not sure, even with the invalidate on resume, no joy. though i could be doing it wrong.
                        def resume(view)
                        view.invalidate
                          driven
                          what are you aiming to achieve?
                          there may be other ways...
                          john
                            CadFather
                            well, first of all i'm trying to avoid going to bed! πŸ˜†
                            i wanted to make a plugin that would show aspect ratio bars and even a grid system, it's almost there, but for the orbit bit(!)
                            this is the beast i'm working with:
                            class Gridz
                             def activate
                             		@width3 = Sketchup.active_model.active_view.vpwidth/3
                            		@height3 = Sketchup.active_model.active_view.vpheight/3
                            		@p1 = @width3, 0, 0
                            		@p6 = @width3, @height3*3, 0
                            		@p2 = @width3*2, 0, 0
                            		@p5 = @width3*2, @height3*3, 0
                            		@p8 = 0, @height3, 0
                            		@p3 = @width3*3, @height3, 0
                            		@p7 = 0, @height3*2, 0
                            		@p4 = @width3*3, @height3*2, 0
                            		view.invalidate
                             def resume(view)
                            		view.invalidate
                             def suspend(view)
                            		view.invalidate
                            def draw(view)
                            		view.line_width = 1
                            		view.draw2d GL_LINES, [@p1, @p6]
                            		view.draw2d GL_LINES, [@p2, @p5]
                            		view.draw2d GL_LINES, [@p8, @p3]
                            		view.draw2d GL_LINES, [@p7, @p4]
                            end   #def
                            def deactivate(view)
                            		view.invalidate
                            end # class
                            UI.menu("Plugins").add_item('Grid'){ Sketchup.active_model.select_tool Gridz.new }
                            file_loaded(File.basename(__FILE__))
                              driven
                              have you ever read 'Automatic Sketchup'?
                              btw: I win the insomniac award...
                              # Create a 4x4 cube
                              square = Sketchup.active_model.entities.add_face [-2,2,0],
                                 [2,2,0], [2,-2,0], [-2,-2,0]
                              square.pushpull -4
                              #Chapter 11; The SketchUp User Interface Part 2; Views, Cameras, Tools, and Pages 251
                              # Access the Pages container and get the time
                              pages = Sketchup.active_model.pages
                              now = Time.now
                              # Create the first page
                              pg1 = pages.add "Pg1"
                              pg1.camera.aspect_ratio = 2
                              pg1.shadow_info["DisplayShadows"] = true
                              pg1.shadow_info["ShadowTime"] = now
                              # Create the second page
                              pg2 = pages.add "Pg2"
                              pg2.camera.aspect_ratio = 1.5
                              pg2.shadow_info["DisplayShadows"] = true
                              pg2.shadow_info["ShadowTime"] =
                                 now + (60 * 60 * 6)
                              # Create the third page
                              pg3 = pages.add "Pg3"
                              pg3.camera.aspect_ratio = 1
                              pg3.shadow_info["DisplayShadows"] = true
                              pg3.shadow_info["ShadowTime"] =
                                 now + (60 * 60 * 12)
                              # Select the first page
                              pages.selected_page = pg1
                                CadFather
                                John...looking at that code looks like you do need the rest! πŸ˜„
                                is that a taster of what's inside the book? i'll check it out. πŸ‘
                                  driven
                                  yes it's straight out of the book, did you run it?
                                  it does change the aspect ratio bars when you play the animation...
                                  and they don't disappear when orbiting...
                                  john
                                  • jiminy-billy-bobJ Offline
                                    jiminy-billy-bob
                                    It's not specific to the Advanced Camera Tools. You can set the camera's aspect ratio yourself, and you'll get the same gray bars on the sides.
                                      driven
                                      @jiminy-billy-bob said:
                                      ...You can set the camera's aspect ratio ourself, and you'll get the same gray bars on the sides.
                                      but, like a lot of examples in the API, it won't just 'work'...
                                      attach it to the view...
                                      Sketchup.active_model.active_view.camera.aspect_ratio = 1.414
                                      that will give you Landscape A4 paper size margins, 1/1.414 will be Portrait...
                                      john
                                        CadFather
                                        that's the thing, often i try things out from the api docs and when it doesn't work, i'm not sure if it's me (my preferred choice) or the doc itself (...)!
                                        John, i hadn't even notice it was relevant... will look it up.
                                        JJB, the aspect ratio bars seem to be governed differently, when you try with lines it doesn't stay on screen (on orbit)
                                        going to 'try' and take a break this evening... my skull hurts! 😲
                                          CadFather
                                          ok, i came to the conclusion that this is impossible. the orbit tool does not allow for anything else to be active. (and the draw method can't be called outside of a 'tool'). πŸ‘Ώ
                                            driven
                                            why do you want the grid lines?
                                            john
                                            • 1 / 2
