    Drawing with GL
    24 Posts 4 Posters 1.3k Views 4 Watching
    • CadFatherC Offline
      CadFather
      ..was trying to fit a 'rule of thirds' on the screen, but trying to avoid using styles.
      this is what i'm aiming at:
      as plan B, i tried saving the current style as a variable, load my 'ratio style with the grid', and reload the previous style upon exit of the tool.
      Incidentally, i found no way to add a style that's already 'in model' - has to be from a saved file. (also no way to save a style to disk from ruby it seems). πŸ˜’
        driven
        that's doable as a watermark...
        but, you need to generate the watermark to match the users viewport width/height...
        that's not as hard as it seems, you can use a webdialog with those as 'client' width/height...
        in the webDialog you add a html5 canvas to draw the grid...
        the blank canvas is centred on the page...
        its height is vph and it's width is 'paper' width [ vph x paper ratio ]...
        grid width is (canvas width minus line weights) Γ· 3
        height is (vph minus line weights) Γ· 3
        line weights e.g 0.5 x 5
        your body background color will show as page margins and the canvas bg needs to be white...
        once drawn, write the image to file then load it as a watermark...
        you need to make the white bg transparent, I'm not sure how on 'windose' from code...
        I think you can toggle watermarks from ruby, but it may need 2 scenes...
        I could dig out some similar code, but you might think it's unrelated...
        john
          driven
          heres a simple test to see if watermarks will do what you want...
          it just your drawgl grid as a watermark with a little tweak, so no dark margins
          to toggle
          Sketchup.active_model.rendering_options["DisplayWatermarks"]=false Sketchup.active_model.rendering_options["DisplayWatermarks"]=true
          and add this as background, use stretch...unzip first...
          is this along the right lines...
            CadFather
            thanks John, already did that though (screenshot above is a watermark).
            the problem with this system is that you are forcing a new style on the user: if the user has a sketchy style on, you cannot have the bars and keep the sketchy style. (in other words we cannot load watermarks without loading a style as well).
            that's why i mentioned about another route: find user current style > save it as variable > load the 'grid' style > restore user style from variable when finished.
            alas, no way to get the previous style back in. whether from the 'in model' style, or trying to save it to a temp directory and loading it back from there. (at least i found no info at all anywhere).
            PS least of all the api docs! 😲
            • 2 / 2
