    Drawing with GL
    24 Posts 4 Posters 2.8k Views 4 Watching
      driven
      they are completely controlled by SU so I guess they has that option...
      but not us...
      EDIT: watermarks will also stay put, they may be using those...
      • CadFatherC
        CadFather
        mmm maybe so, advanced camera tools is a ruby script though.
        unfortunately it's flipping scrambled πŸ˜’
          When you orbit the Orbit tool is pushed into the tool stack - suspending your tool. So you have to invalidate the view in the resume event. You also want to invalidate the view on deactivate as otherwise your drawing might stick around after your tool is not active any more.
          • CadFatherC
            CadFather
            not sure, even with the invalidate on resume, no joy. though i could be doing it wrong.
            def resume(view)
            view.invalidate
              driven
              what are you aiming to achieve?
              there may be other ways...
              • CadFatherC
                CadFather
                well, first of all i'm trying to avoid going to bed! πŸ˜†
                i wanted to make a plugin that would show aspect ratio bars and even a grid system, it's almost there, but for the orbit bit(!)
                this is the beast i'm working with:
                class Gridz
                 def activate
                 		@width3 = Sketchup.active_model.active_view.vpwidth/3
                		@height3 = Sketchup.active_model.active_view.vpheight/3
                		@p1 = @width3, 0, 0
                		@p6 = @width3, @height3*3, 0
                		@p2 = @width3*2, 0, 0
                		@p5 = @width3*2, @height3*3, 0
                		@p8 = 0, @height3, 0
                		@p3 = @width3*3, @height3, 0
                		@p7 = 0, @height3*2, 0
                		@p4 = @width3*3, @height3*2, 0
                def onMouseMove(flags, x, y, view)
                		view.invalidate
                 def resume(view)
                		view.invalidate
                 def suspend(view)
                		view.invalidate
                def draw(view)
                		model = Sketchup.active_model
                		view = model.active_view
                		view.line_width = 1
                		view.drawing_color = "red"
                		view.draw2d GL_LINES, [@p1, @p6]
                		view.draw2d GL_LINES, [@p2, @p5]
                		view.draw2d GL_LINES, [@p8, @p3]
                		view.draw2d GL_LINES, [@p7, @p4]
                end   #def
                def deactivate(view)
                		view.invalidate
                end # class
                if !file_loaded?(File.basename(__FILE__))
                UI.menu("Plugins").add_item('Grid'){ Sketchup.active_model.select_tool Gridz.new }
                file_loaded(File.basename(__FILE__))
                  driven
                  have you ever read 'Automatic Sketchup'?
                  btw: I win the insomniac award...
                  # Create a 4x4 cube
                  square = Sketchup.active_model.entities.add_face [-2,2,0],
                     [2,2,0], [2,-2,0], [-2,-2,0]
                  square.pushpull -4
                  #Chapter 11; The SketchUp User Interface Part 2; Views, Cameras, Tools, and Pages 251
                  # Access the Pages container and get the time
                  pages = Sketchup.active_model.pages
                  now = Time.now
                  # Create the first page
                  pg1 = pages.add "Pg1"
                  pg1.camera.aspect_ratio = 2
                  pg1.shadow_info["DisplayShadows"] = true
                  pg1.shadow_info["ShadowTime"] = now
                  # Create the second page
                  pg2 = pages.add "Pg2"
                  pg2.camera.aspect_ratio = 1.5
                  pg2.shadow_info["DisplayShadows"] = true
                  pg2.shadow_info["ShadowTime"] =
                     now + (60 * 60 * 6)
                  # Create the third page
                  pg3 = pages.add "Pg3"
                  pg3.camera.aspect_ratio = 1
                  pg3.shadow_info["DisplayShadows"] = true
                  pg3.shadow_info["ShadowTime"] =
                     now + (60 * 60 * 12)
                  # Select the first page
                  pages.selected_page = pg1
                  • CadFatherC
                    CadFather
                    John...looking at that code looks like you do need the rest! πŸ˜„
                    is that a taster of what's inside the book? i'll check it out. πŸ‘
                      driven
                      yes it's straight out of the book, did you run it?
                      it does change the aspect ratio bars when you play the animation...
                      and they don't disappear when orbiting...
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        It's not specific to the Advanced Camera Tools. You can set the camera's aspect ratio yourself, and you'll get the same gray bars on the sides.
                          driven
                          @jiminy-billy-bob said:
                          ...You can set the camera's aspect ratio ourself, and you'll get the same gray bars on the sides.
                          but, like a lot of examples in the API, it won't just 'work'...
                          attach it to the view...
                          Sketchup.active_model.active_view.camera.aspect_ratio = 1.414
                          that will give you Landscape A4 paper size margins, 1/1.414 will be Portrait...
                          • CadFatherC
                            CadFather
                            that's the thing, often i try things out from the api docs and when it doesn't work, i'm not sure if it's me (my preferred choice) or the doc itself (...)!
                            John, i hadn't even notice it was relevant... will look it up.
                            JJB, the aspect ratio bars seem to be governed differently, when you try with lines it doesn't stay on screen (on orbit)
                            going to 'try' and take a break this evening... my skull hurts! 😲
                            • CadFatherC
                              CadFather
                              ok, i came to the conclusion that this is impossible. the orbit tool does not allow for anything else to be active. (and the draw method can't be called outside of a 'tool'). πŸ‘Ώ
                                driven
                                why do you want the grid lines?
                                • CadFatherC
                                  CadFather
                                  ..was trying to fit a 'rule of thirds' on the screen, but trying to avoid using styles.
                                  this is what i'm aiming at:
                                  as plan B, i tried saving the current style as a variable, load my 'ratio style with the grid', and reload the previous style upon exit of the tool.
                                  Incidentally, i found no way to add a style that's already 'in model' - has to be from a saved file. (also no way to save a style to disk from ruby it seems). πŸ˜’
                                    driven
                                    that's doable as a watermark...
                                    but, you need to generate the watermark to match the users viewport width/height...
                                    that's not as hard as it seems, you can use a webdialog with those as 'client' width/height...
                                    in the webDialog you add a html5 canvas to draw the grid...
                                    the blank canvas is centred on the page...
                                    its height is vph and it's width is 'paper' width [ vph x paper ratio ]...
                                    grid width is (canvas width minus line weights) Γ· 3
                                    height is (vph minus line weights) Γ· 3
                                    line weights e.g 0.5 x 5
                                    your body background color will show as page margins and the canvas bg needs to be white...
                                    once drawn, write the image to file then load it as a watermark...
                                    you need to make the white bg transparent, I'm not sure how on 'windose' from code...
                                    I think you can toggle watermarks from ruby, but it may need 2 scenes...
                                    I could dig out some similar code, but you might think it's unrelated...
                                      driven
                                      heres a simple test to see if watermarks will do what you want...
                                      it just your drawgl grid as a watermark with a little tweak, so no dark margins
                                      to toggle
                                      Sketchup.active_model.rendering_options["DisplayWatermarks"]=false Sketchup.active_model.rendering_options["DisplayWatermarks"]=true
                                      and add this as background, use stretch...unzip first...
                                      is this along the right lines...
                                      • CadFatherC
                                        CadFather
                                        thanks John, already did that though (screenshot above is a watermark).
                                        the problem with this system is that you are forcing a new style on the user: if the user has a sketchy style on, you cannot have the bars and keep the sketchy style. (in other words we cannot load watermarks without loading a style as well).
                                        that's why i mentioned about another route: find user current style > save it as variable > load the 'grid' style > restore user style from variable when finished.
                                        alas, no way to get the previous style back in. whether from the 'in model' style, or trying to save it to a temp directory and loading it back from there. (at least i found no info at all anywhere).
                                        PS least of all the api docs! 😲
