    [Plugin] Add Icons [for all SU files on mac]
    47 Posts 8 Posters 11.9k Views 8 Watching
      driven
      what does this return on retina...
      UI;;WebDialog;;new.screen_scale_factor
      john
      • G Offline
        greatoe
        UI::WebDialog::new.screen_scale_factor
        2.0
          driven
          @greatoe said:
          2.0
          excellent...
          I'll add that inn
          john
            driven
            if you paste the code block below first, then JcB::SetWindowSize::Change.set_2_square
            does it 'go' square?
            then up arrow in 'Ruby Console' >> return
            does it revert?
            =begin
            Copyright 2015, john@drivenupthewall.co.uk
            All Rights Reserved - for now...
            =end
            module JcB
              module SetWindowSize
                class  Change
                @plist = (ENV["XPC_SERVICE_NAME"]).split('.')[0..-2].join('.')
                @scale = UI;;WebDialog;;new.screen_scale_factor.to_f
                def self.vpw
                  Sketchup.active_model.active_view.vpwidth / @scale
                def self.vph
                  Sketchup.active_model.active_view.vpheight / @scale
                def self.win_read
                  %x(defaults  read  #{@plist}      "NSWindow Frame SketchUpDoc")
                def self.frame_read
                  %x(defaults  read  #{@plist}     "Sketchup.MainFrameSize")
                def self.win_write(arry)
                  %x(defaults  write  #{@plist}      "NSWindow Frame SketchUpDoc" #{arry})
                def self.frame_write(hash)
                 %x(defaults  write  #{@plist}     "Sketchup.MainFrameSize" -string "#{hash}")
                def self.su_window
                  win_read.chomp!.split(' ').map{|e| e.to_i}
                def self.main_frame
                  frame_read.chomp!.gsub(/[\{\}]/, '').split(', ').map{|e| e.to_i}
                SUD = win_read.dup.chomp!   if not defined? SUD
                SMF = frame_read.dup.chomp! if not defined? SMF
                @@revert = false if not defined? SUD
                  def self.default_paper
                   ##'shipped' ratios with a few international paper sizes...
                   ratios = { 1.0=>'Square', 1.294=>'US Letter', 1.333=>'US Architectural',\
                                      1.414=>'A Series (ISO 216)', 1.647=>'US Legal'}
                   type = %x(defaults read com.apple.print.PrintingPrefs DefaultPaperID)
                   if type.include? 'Letter'
                     ratio = 1.294
                   elsif type.include? 'Arch'
                     ratio = 1.333
                   elsif type.include? 'iso'
                     ratio = 1.414
                   elsif type.include? 'Legal'
                     ratio = 1.647
                   else
                      prompts = [($add_icon_strngs["Select your Paper Type"])]
                      defaults = []
                      ratios.map{|k,v| defaults << v }
                      choose = defaults.join(',').gsub(',', '|')
                      input = UI.inputbox(prompts, [defaults[0]],[choose],  ($add_icon_strngs[" You have no 'default' Printer set "]))
                       if input.include? 'Letter'
                         ratio = 1.294
                       elsif input.include? 'Arch'
                         ratio = 1.333
                       elsif input.include? 'iso'
                         ratio = 1.414
                       elsif input.include? 'Legal'
                         ratio = 1.647
                       else
                         ratio = 1
                   @ratio = ratio
                  def self.process_window
                    su_window
                    sul = su_window[0] # left top corner
                    suo = su_window[1] # left bottom corner
                    suw = su_window[2] # width
                    suh = su_window[3] #
                    mcl = su_window[4] #
                    mco = su_window[5] #
                    mcw = su_window[6] #
                    mch = su_window[7] #
                    new_doc = "#{sul} #{suo} #{@new_width} #{suh} #{mcl} #{mco} #{mcw} #{mch}"
                    main_frame
                    mfa = main_frame[0]
                    mfb = main_frame[1]
                    mfc = main_frame[2] # width
                    mfd = main_frame[3]
                    new_mf = "\{\{#{mfa}, #{mfb}\}, \{#{@new_width}, #{mfd}\}\}"
                    mod_path = Sketchup.active_model.path
                    Sketchup.active_model.select_tool(nil)
                    Sketchup.active_model.close_active
                    Sketchup.send_action('closeDocument;')
                      if not @@revert
                        frame_write(new_mf)
                        win_write(new_doc)
                        @@revert = true
                      else
                        win_revert
                   mod_path != '' ? Sketchup.open_file(mod_path) ; Sketchup.send_action('newDocument;')
                  def self.win_revert
                        frame_write(SMF)
                        win_write(SUD)
                        @@revert = false
                  def self.set_2_print
                    default_paper
                    @new_width = (vph * @ratio)
                    @@revert = (vpw.between?( @new_width - 3, @new_width + 3 ))
                    process_window
                  def self.set_2_square
                    @new_width = vph
                    process_window
                  class AddIconWindowObserver < Sketchup;;AppObserver
                    def onQuit
                      revert = JcB;;SetWindowSize;;Change.class_variable_get(;@@revert) || false
                      SetWindowSize;;Change.frame_write(SMF) if revert
                      SetWindowSize;;Change.win_write(SUD)   if revert
                     # Attach the observer
                     Sketchup.add_observer(AddIconWindowObserver.new)
                end # change
              end # module
            #  JcB;;SetWindowSize;;Change.set_2_square
            • G Offline
              greatoe
              1. up arrow >> return again
                the new blank SketchUp window go square;
              the new blank SketchUp window revert its size, but goes to a new position on screen;
              I kept doing this, results are same: the new blank SketchUp window do go square and revert, but the position on screen is changing.
              • G Offline
                greatoe
                1. I draw something in the new blank SketchUp window, save the file.
                  the "square - revert with different position" circle goes on.
                2. I close SketchUp, open it again (with and without an existing file), I do 1) and 2), the result is same as 3).
                • G Offline
                  greatoe
                  1. I pasted the code, hit return
                    ruby console return "True";
                  2. JcB::SetWindowSize::Change.set_2_square, return
                    and SketchUp ask me if I want to save my current work;
                  3. I click "yes"
                    ruby console return the following:
                    Error: #<NoMethodError: undefined method attribute_dictionary' for nil:NilClass> /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:189:in onContentsModified'
                  if I click "no"
                  ruby console return:
                  Error: #<TypeError: reference to deleted Attribute>
                  /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:203:in each' /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:203:in block in onContentsModified'
                  SketchUp:1:in `call'
                  then the window of my current work is closed, while SketchUp is still running;
                  then I click the SketchUp icon on the Dock, a blank/new SketchUp window pops up, which is square.
                  1. I press up arrow in ruby console then return
                    the new SketchUp window revert to previous size, but a little different with its position on screen.
                    driven
                    cheers for that comprehensive testing,
                    Is that the latest version of jbb_layers_panel that's causing the errors?
                    for some reason it's observers are being triggered by closing and re-opening the SU window...
                    If you temporarily disable it does this code run without issue?
                    In Preferences, do you have 'new windows' set to 'cascade'?
                    If so does after deselecting that does the top corner still move?
                    I do have a completely different 'new' way of changing the window width, but that also needs more testing...
                    john
                    • G Offline
                      greatoe
                      the latest version 1.0.2 and a previous version work same;
                      how to temporarily disable the observers?
                      yes 'new windows' are set to 'cascade', deselecting this solved the window moving problem
                        driven
                        I was meaning the version of 'layer panels' it's throwing those errors, if you disable it then it's observers shouldn't run...
                        I can turn that on and off in code so I'll add it in...
                        I'd forgotten that dave had that problem on another version...
                        • G Offline
                          greatoe
                          sorry I didn't read your words carefully.
                          I removed jbb_layers_panel, no more error message in ruby console.
                          however the close/open window issue remains:
                          I paste the code and return
                          JcB::SetWindowSize::Change.set_2_square and return
                          SketchUp ask if I want to save my file
                          no matter yes or no the window is closed
                          I manually re-open the window, continue with up arrow return, window transform forward and backward works fine afterwards.
                            driven
                            I've been adding a catch for that as well, so it waits for you to save...
                            got it working for 'Unsaved' just need to add some code for modified ones as well...
                            john
                              driven
                              here's a test version that hopefully deals with the retina and other v15 issues...
                              set_square and set_printer should both deal with unsaved models or changes, but you then need to re-select the option...
                              EDIT: removed test file
                              PM me if you can do any testing and I'll send you a rbz...
                              john
                              • jojo9J Offline
                                jojo9
                                luxurious way to add icons…nice one!
                                however, the batch command doesnt work for me…i get the loading image, but this process continues forever. Where looks your plugin for, example, "*.skp" files?
                                Else, thanks!
                                oh, i forget : im on Mac 10.7.5, and use Su13 make
                                  driven
                                  cheers, I got sick of waiting for native icons...
                                  this is down to me not using v2013 anymore, and not having the time to go back in time to fix it...
                                  In batch mode, it should open a 'Finder' window that lets you look anywhere you want, it is best to target small collections, i.e. if I target 'Downloads' it will try process the 206 files without icons and if any are corrupt files it can crash SU, but I have also done folders with 500+ skps that I've created without any issues...
                                  that is probably the issue, the single mode should work for any SU version, and some people can run batch mode in earlier versions, so it hard to figure out the problem...
                                  I'll try to find some time to revisit...
                                  john
                                    sketchuh
                                    like to donate thru paypal. your add icons plugin works. what is your paypal address. u can pm me. Thanks.
                                      sketchuh
                                      i have to resize the sketchup window size to a square , if i want the thumb nail to be square. otherwise, my thumnails are always with red bands. the square button doesn't work.
                                      also, can you change the red color to white or grey? thanks
                                        driven
                                        Hi sketchuh,
                                        are you still on SU v15 , which version of osx do you run and do you have a retina display?
                                        I've been doing some more work on this, but it's not quite ready...
                                        can I PM you some test files?
                                        john
                                          sketchuh
                                          yes john!
                                          I am using sketchup 2015 on macbook pro retina 2013. and using the latest os system.
                                            sketchuh
                                            actually, when chose the batch mode, almost all other sktechup files would have square thumb nails, only one that is opened has red bands if the viewport is not square.
                                            • 2 / 3
