    [Plugin] Add Icons [for all SU files on mac]
    47 Posts 8 Posters 15.5k Views 8 Watching
      driven
      @greatoe said:
      2.0
      excellent...
      I'll add that inn
        driven
        if you paste the code block below first, then JcB::SetWindowSize::Change.set_2_square
        does it 'go' square?
        then up arrow in 'Ruby Console' >> return
        does it revert?
        =begin
        Copyright 2015, john@drivenupthewall.co.uk
        All Rights Reserved - for now...
        =end
        module JcB
          module SetWindowSize
            class  Change
            @plist = (ENV["XPC_SERVICE_NAME"]).split('.')[0..-2].join('.')
            @scale = UI;;WebDialog;;new.screen_scale_factor.to_f
            def self.vpw
              Sketchup.active_model.active_view.vpwidth / @scale
            def self.vph
              Sketchup.active_model.active_view.vpheight / @scale
            def self.win_read
              %x(defaults  read  #{@plist}      "NSWindow Frame SketchUpDoc")
            def self.frame_read
              %x(defaults  read  #{@plist}     "Sketchup.MainFrameSize")
            def self.win_write(arry)
              %x(defaults  write  #{@plist}      "NSWindow Frame SketchUpDoc" #{arry})
            def self.frame_write(hash)
             %x(defaults  write  #{@plist}     "Sketchup.MainFrameSize" -string "#{hash}")
            def self.su_window
              win_read.chomp!.split(' ').map{|e| e.to_i}
            def self.main_frame
              frame_read.chomp!.gsub(/[\{\}]/, '').split(', ').map{|e| e.to_i}
            SUD = win_read.dup.chomp!   if not defined? SUD
            SMF = frame_read.dup.chomp! if not defined? SMF
            @@revert = false if not defined? SUD
              def self.default_paper
               ##'shipped' ratios with a few international paper sizes...
               ratios = { 1.0=>'Square', 1.294=>'US Letter', 1.333=>'US Architectural',\
                                  1.414=>'A Series (ISO 216)', 1.647=>'US Legal'}
               type = %x(defaults read com.apple.print.PrintingPrefs DefaultPaperID)
               if type.include? 'Letter'
                 ratio = 1.294
               elsif type.include? 'Arch'
                 ratio = 1.333
               elsif type.include? 'iso'
                 ratio = 1.414
               elsif type.include? 'Legal'
                 ratio = 1.647
               else
                  prompts = [($add_icon_strngs["Select your Paper Type"])]
                  defaults = []
                  ratios.map{|k,v| defaults << v }
                  choose = defaults.join(',').gsub(',', '|')
                  input = UI.inputbox(prompts, [defaults[0]],[choose],  ($add_icon_strngs[" You have no 'default' Printer set "]))
                   if input.include? 'Letter'
                     ratio = 1.294
                   elsif input.include? 'Arch'
                     ratio = 1.333
                   elsif input.include? 'iso'
                     ratio = 1.414
                   elsif input.include? 'Legal'
                     ratio = 1.647
                   else
                     ratio = 1
               @ratio = ratio
              def self.process_window
                su_window
                sul = su_window[0] # left top corner
                suo = su_window[1] # left bottom corner
                suw = su_window[2] # width
                suh = su_window[3] #
                mcl = su_window[4] #
                mco = su_window[5] #
                mcw = su_window[6] #
                mch = su_window[7] #
                new_doc = "#{sul} #{suo} #{@new_width} #{suh} #{mcl} #{mco} #{mcw} #{mch}"
                main_frame
                mfa = main_frame[0]
                mfb = main_frame[1]
                mfc = main_frame[2] # width
                mfd = main_frame[3]
                new_mf = "\{\{#{mfa}, #{mfb}\}, \{#{@new_width}, #{mfd}\}\}"
                mod_path = Sketchup.active_model.path
                Sketchup.active_model.select_tool(nil)
                Sketchup.active_model.close_active
                Sketchup.send_action('closeDocument;')
                  if not @@revert
                    frame_write(new_mf)
                    win_write(new_doc)
                    @@revert = true
                  else
                    win_revert
               mod_path != '' ? Sketchup.open_file(mod_path) ; Sketchup.send_action('newDocument;')
              def self.win_revert
                    frame_write(SMF)
                    win_write(SUD)
                    @@revert = false
              def self.set_2_print
                default_paper
                @new_width = (vph * @ratio)
                @@revert = (vpw.between?( @new_width - 3, @new_width + 3 ))
                process_window
              def self.set_2_square
                @new_width = vph
                process_window
              class AddIconWindowObserver < Sketchup;;AppObserver
                def onQuit
                  revert = JcB;;SetWindowSize;;Change.class_variable_get(;@@revert) || false
                  SetWindowSize;;Change.frame_write(SMF) if revert
                  SetWindowSize;;Change.win_write(SUD)   if revert
                 # Attach the observer
                 Sketchup.add_observer(AddIconWindowObserver.new)
            end # change
          end # module
        #  JcB;;SetWindowSize;;Change.set_2_square
          greatoe
          1. up arrow >> return again
            the new blank SketchUp window go square;
          the new blank SketchUp window revert its size, but goes to a new position on screen;
          I kept doing this, results are same: the new blank SketchUp window do go square and revert, but the position on screen is changing.
            greatoe
            1. I draw something in the new blank SketchUp window, save the file.
              the "square - revert with different position" circle goes on.
            2. I close SketchUp, open it again (with and without an existing file), I do 1) and 2), the result is same as 3).
              greatoe
              1. I pasted the code, hit return
                ruby console return "True";
              2. JcB::SetWindowSize::Change.set_2_square, return
                and SketchUp ask me if I want to save my current work;
              3. I click "yes"
                ruby console return the following:
                Error: #<NoMethodError: undefined method attribute_dictionary' for nil:NilClass> /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:189:in onContentsModified'
              if I click "no"
              ruby console return:
              Error: #<TypeError: reference to deleted Attribute>
              /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:203:in each' /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:203:in block in onContentsModified'
              SketchUp:1:in `call'
              then the window of my current work is closed, while SketchUp is still running;
              then I click the SketchUp icon on the Dock, a blank/new SketchUp window pops up, which is square.
              1. I press up arrow in ruby console then return
                the new SketchUp window revert to previous size, but a little different with its position on screen.
                driven
                cheers for that comprehensive testing,
                Is that the latest version of jbb_layers_panel that's causing the errors?
                for some reason it's observers are being triggered by closing and re-opening the SU window...
                If you temporarily disable it does this code run without issue?
                In Preferences, do you have 'new windows' set to 'cascade'?
                If so does after deselecting that does the top corner still move?
                I do have a completely different 'new' way of changing the window width, but that also needs more testing...
                  greatoe
                  the latest version 1.0.2 and a previous version work same;
                  how to temporarily disable the observers?
                  yes 'new windows' are set to 'cascade', deselecting this solved the window moving problem
                    driven
                    I was meaning the version of 'layer panels' it's throwing those errors, if you disable it then it's observers shouldn't run...
                    I can turn that on and off in code so I'll add it in...
                    I'd forgotten that dave had that problem on another version...
                      greatoe
                      sorry I didn't read your words carefully.
                      I removed jbb_layers_panel, no more error message in ruby console.
                      however the close/open window issue remains:
                      I paste the code and return
                      JcB::SetWindowSize::Change.set_2_square and return
                      SketchUp ask if I want to save my file
                      no matter yes or no the window is closed
                      I manually re-open the window, continue with up arrow return, window transform forward and backward works fine afterwards.
                        driven
                        I've been adding a catch for that as well, so it waits for you to save...
                        got it working for 'Unsaved' just need to add some code for modified ones as well...
                          driven
                          here's a test version that hopefully deals with the retina and other v15 issues...
                          set_square and set_printer should both deal with unsaved models or changes, but you then need to re-select the option...
                          EDIT: removed test file
                          PM me if you can do any testing and I'll send you a rbz...
                          • jojo9J Offline
                            jojo9
                            luxurious way to add icons…nice one!
                            however, the batch command doesnt work for me…i get the loading image, but this process continues forever. Where looks your plugin for, example, "*.skp" files?
                            Else, thanks!
                            oh, i forget : im on Mac 10.7.5, and use Su13 make
                              driven
                              cheers, I got sick of waiting for native icons...
                              this is down to me not using v2013 anymore, and not having the time to go back in time to fix it...
                              In batch mode, it should open a 'Finder' window that lets you look anywhere you want, it is best to target small collections, i.e. if I target 'Downloads' it will try process the 206 files without icons and if any are corrupt files it can crash SU, but I have also done folders with 500+ skps that I've created without any issues...
                              that is probably the issue, the single mode should work for any SU version, and some people can run batch mode in earlier versions, so it hard to figure out the problem...
                              I'll try to find some time to revisit...
                                sketchuh
                                like to donate thru paypal. your add icons plugin works. what is your paypal address. u can pm me. Thanks.
                                  sketchuh
                                  i have to resize the sketchup window size to a square , if i want the thumb nail to be square. otherwise, my thumnails are always with red bands. the square button doesn't work.
                                  also, can you change the red color to white or grey? thanks
                                    driven
                                    Hi sketchuh,
                                    are you still on SU v15 , which version of osx do you run and do you have a retina display?
                                    I've been doing some more work on this, but it's not quite ready...
                                    can I PM you some test files?
                                      sketchuh
                                      yes john!
                                      I am using sketchup 2015 on macbook pro retina 2013. and using the latest os system.
                                        sketchuh
                                        actually, when chose the batch mode, almost all other sktechup files would have square thumb nails, only one that is opened has red bands if the viewport is not square.
                                          driven
                                          if you want to change the red to Finder off white, copy/paste this code into 'Ruby Console' and hit Return...
                                          it should work without needing a restart of SU...
                                          filename = Sketchup.find_support_file("jcb_Add_Icon/Add_icon_logic.rb", 'Plugins')
                                          text = File.read(filename)
                                          content = text.gsub(/ FF0000 /, " e8e9e8 ")
                                          File.open(filename, "w") { |file| file << content }
                                            sketchuh
                                            thanks, the red is changed.
                                            just want to confirm do i have to resize the window to square in order to have the thumb nail square?
                                            • 2 / 3
