    Follow me and keep problem
    8 Posts 4 Posters 625 Views 4 Watching
    • E Offline
      elmer
      Hi all,
      Can not make FAK works....on this very simple path and face!
      Have review tutorials and all sorts of stuff!
      Thanks to any one help.
      FAK.skp
        FAK is by now a very old script.
        There are better alternatives.
        Like: http://sketchucation.com/pluginstore?pln=ene_uprightExtruder_v1.2.0
        Why not try that?
        I works.
        • E Offline
          elmer
          Thanks a lot TIG for this quick answer.
          Well you know I'm old too... πŸ˜†
          I downloaded Upright extrude but get wierd result....
          Any other bright idea?
          Many thanks.
          FAK-Upright extrude test.skp
            Well with the 'normal' vector set to z [0,0,1] you get the face kept flat, so the extrusion properly done.
            The extruded face is continually 'flat'.
            Try setting an x or y and you'll get different results.
            Alternatively a simple native FollowMe will keep a consistent cross-section but inevitably the extrusions will twist as it progresses along the path...
            You could also look at copying the profile face onto the end of the path, oriented as you'd like the extrusion to finish, then using CurviLoft, to loft along the path using those two profiles as start/finish faces...
            http://sketchucation.com/pluginstore?pln=Curviloft
            Don't forget you'll also need to have LibFredo installed...
            http://sketchucation.com/pluginstore?pln=LibFredo6
            • BoxB Offline
              That didn't sound right.
              Have you tried Tig's extrude edges by face.
                sdmitch
                @elmer said:
                Hi all,
                It seems to be an orientation problem. In your model, I copied the face and curve, rotated both face and curve so that the face was upright. Then rotated just the face so that it was perpendicular to the first edge and FAK worked.
                FAK.skp
                http://sdmitch.blogspot.com/
                • E Offline
                  elmer
                  Thank you all for your help.
                  As a matter of fact, as sdmitch noticed, it looks like I was starting with a wrong orientation of the face 😳 .
                  To help you understand what I'm trying to do see the picture.
                  With a correct angle for the starting face native follow me tool does the job.
                  @ Box : YES I have but as long as the starting face was badly oriented....
                  Thanks again!
                  FAK-correct.skp
                    Yes, with the native FollowMe you need the profile face to be square to the first segment of the path.
                    My ExtrudeEdgesByFace will actually do that for you [doh!] πŸ˜’
