    Vegetation to 3rd party?
    4 Posts 3 Posters 417 Views 3 Watching
    • P
      paolo
      Hi, I will like to learn how to add a lot of 3d vegetation to some of my sketchup models in a photorealistic manner. I'm not sure that even with the new vray 2.0 and proxys I could achieve it without having to worry about polygon count all the time.
      Could you guys advice what third party software to use? I'm thinking something widely use, in a good price and not too difficult to learn. 3d max, Vue, LumenRT, Maya? I believe that will have to render there but would I be able to keep textures?
      Thanks for any comment or advice.
      • oceanembersO
        oceanembers
        For modeling, I use a software called The Plant Factory, but it's a little on the pricey side. SpeedTree is very similar (better in some areas, worse in others), and is available on a monthly subscription for much less money.
        You can then go on to export, and render in whatever software you want.
        • JQLJ
          JQL
          The poly count side of things is solved by turning your trees into proxies...
          www.casca.pt
          Visit us on facebook!
          • P
            paolo
            Thanks Ocean & Casca, yes I have looked at Plant factory and will check Speedtree, actually I'm not too concern about something a bit pricey as long as is good, widely used and not too complicate to learn.
            Does proxy in sketchup solve the problem even if I use many different plants of 15mb + each? to be honest I have not used the new vray 2.0 yet.
            Will be nice to make like a poll to see what people here are using to deal with photorealistic vegetation.
