    Light through the glass door
    renderpluginsextensions
    5 Posts 3 Posters 856 Views 3 Watching
      ania1sun
      [color=#BF00FF:1yawc00j]%(#FF40BF)[Hi,
      I am creating a NIGHT indoor scene. I want the light in another room to be visible through the glass door in my prior interior. I used rectangle light placed on the door so to achieve an illumination comming from another room. I did emissive material out of the glass surface but it is not transparent anymore. How to make the glass being bright and transparent at the same time in a NIGHT indoor scene.][/color]
      • chonC Offline
        chon
        Hello,
        if you use a rectangular light outside your door, you don't need to use an emissive on your glass.
        Try to affect a glass material on your door window (can be downloaded on Chaos web site if you want to be sure having a well setted material), don't paste your rectangular light on the door but leave a space between them to have a realistic light ray through your door and it should work... πŸ˜‰
        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
        • V Offline
          valerostudio
          You need to model it the way it would be in real life. Glass door, place an omni light inside the room that is to 'glow'.
            ania1sun
            If I understood you correctly you advice me to apply setted glass material from Chaos web site. Could you please write where on Chaos web site I can find it ?
            @chon said:
            Hello,
            • chonC Offline
              chon
              Here.
              You need to be logged in to have access.
