    Trouble with drawing a helix on part of a torus?
    7 Posts 5 Posters 710 Views 5 Watching
    • N Offline
      nwarner33
      Sorry I dont know how to describe it. But I need to be able to draw spiral, going around this shape. I tried to lay on a texture to give you the idea. Even that I struggled with.
      I know there is the plugin by Fredo, but does anyone have another technique, or could explain how using the Fredo plugin, that you could achieve such a thing?
      Many thanks!!
      • cottyC Offline
        cotty
        You don't need a plugin for this, use a projected texture for it...
        my SketchUp gallery
        • jeff hammondJ Offline
          jeff hammond
          @nwarner33 said:
          [attachment=2:1aisadoc]<!-- ia2 -->Screen Shot 2015-01-29 at 17.47.17.png<!-- ia2 -->[/attachment:1aisadoc]
          that's going to be pretty tricky to do in sketchup.. does it have to be geometry or is a texture ok?
          if geometry and you only need it for a one time thing, i could do it for you in a different application really quick.. (would need the base geometry then how many revolutions you're looking for)
          [attachment=1:1aisadoc]<!-- ia1 -->Screen Shot 2015-01-29 at 2.30.53 PM.png<!-- ia1 -->[/attachment:1aisadoc]
          EDIT
          or, i guess in sketchup, with the proper setup geometry and a bit of experimenting with segment count etc, you could just draw the spiral manually using the hidden geometry as a guide?
          [attachment=0:1aisadoc]<!-- ia0 -->spiral.jpg<!-- ia0 -->[/attachment:1aisadoc]
          a rough go at it in sketchup.. the pitch is changing in this example but with enough experimentation/calculation, i think you could get it consistent.
          dotdotdot
          • N Offline
            nwarner33
            Thanks so much for your responses. I guess for the render side of it, the projected texture is perfect.
            I do unfortunately need to model it correctly further down the line. I know it is easy enough in Rhino, but I only have extremely basic rhino knowledge.
            As it is part of an ongoing product development, it will need to be modelled, tried and tested, various times. It needs to be a very specifically sized, exponential spiral, which makes it difficult.
            Jeff, was it rhino that you would use to do it as a one time thing? Is there any chance you tell me the tools you would use, if so?
            Thanks again.
            • S ShepherdS Offline
              S Shepherd
              This seems familiar. We covered some of this a while back for someone looking for a specific angle and slope etc.
              Have a look here:
              http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=53674
              Shep
                jeff hammond
                right.. rhino
                assuming you have the shape already (which is just drawing the profile curve then using the _Revolve command on it)..
                the spiral can then be drawn with _InterpCrvOnSrf (via menu: Curve-> FreeForm-> Interpolate on Surface)..
                with that command, you can set the start point then just keep spinning the cursor around a revolved surface...
                dotdotdot
                  The Jeff sombrero! β˜€
                  Some variation πŸ˜„
