    Camera wide angle
    16 Posts 5 Posters 8.3k Views 5 Watching
    • M
      maccabist
      Hello
      I have a high building project as an architecture student of 8 stores.
      In perspective mode - i located the camera close to the entrance to catch important details
      but unable to see the entire building - to the top. i dont want to place the camera backward in order not to loose the details. is there a solution to it? a wide angle camera plugin? i dont use other apps like v ray to use the "TT VRAY TOOLS" PLUGIN.
      Thanks a lot
      Maccabist
        You don't need a plugin to get a wide field of view. Just select the Zoom tool from the toolbar or the camera menu and type either the desired angle of view or a lens focal length, i.e. 28mm and hit Enter.
        • cottyC
          cotty
          If the zoom tool is selected, you get helpful hints in the status row (left bottom)...
          my SketchUp gallery
          • M
            maccabist
            Hello Dave and Cotty.
            Thanks so much for your response. however, the issue is that i dont want to raise the value
            of "field of view" because of the distortion of the perspective. i use around 50 as close
            to human eye. it feels like the top of my screen cuts the perspective. it's like : i want
            to look at the building from very close but still to be able to see the entire.
            Thanks again
            πŸ˜„
              I don't think you understand how field of view works. There's no alternative if you want to get everything in a single view. If you were photographing a real building from the same distance with a camera with the lens as you want to use in SketchUp, you'd have the same problem. The alternatives would be to stand farther away or using a shorter focal length lens.
              • olisheaO
                olishea
                Personally I would make a vertical panorama and then eliminate the converging verticals in photoshop.
                oli
                • M
                  maccabist
                  Thanks Oli.
                  This is what i tried but its precise only in "2 point perspective" which is a big compromise. i wonder why the perspectiv outline should be limited to the area of the monitor.
                  Thanks a lot to all of you πŸ˜„
                    That's like asking, "I wonder why the photo is limited to the area the lens covers."
                    • olisheaO
                      olishea
                      What do you mean precise? You mean when you line up the images after?
                      Use a panorama software or photoshop photomerge. Should be really easy. Then just get rid of the convergence.
                      oli
                      • S
                        slbaumgartner
                        SketchUp's perspective views model the behavior of a real camera. I suspect you are not a photographer, since what you desire could not be done with a real camera either except using the perspective tools olishea proposes. SketchUp's "two-point perspective" just points the camera level, which prevents "converging verticals" just as in a real camera. It does nothing to magically make the camera see more than is possible using the lens and distance you choose.
                        • olisheaO
                          olishea
                          Can you tilt shift the camera in your render app?
                          http://static.bhphotovideo.com/explora/explora/sites/default/files/no_distortion_diptych.jpg
                          oli
                          • M
                            maccabist
                            Thanks to all of you for responding.
                            its my first post in this wonderfull site.
                            i'm not a photographer although i'm familiar with general issues. i use sketchup for 5 yrs
                            and most of all i'm a student of Architecture from israel.
                            I use Sketchup + Photoshop only. i'm aware i might miss something
                            in my question and that sketchup mimic a real camera.
                            However, after all its not a real camera. to oli : "precise" - i ment that by taking photos panoramically in "2 point perspective" mode it will be acurate to "glue" them together in photoshop (photos from 1/3 , 2/3 , 3/3 height of the building). it will not be accurate in "perspective" mode. by tilt+Shift of course.
                            I know in Vray there is option to configure the rendered photo to be wider then it apears on the screen.
                            bless you
                            • S
                              slbaumgartner
                              bless you
                              You could export a series of 2D graphics in 2-point perspective by shifting the camera's eye point vertically between "shots". These views could then be pasted together in PhotoShop or an equivalent image editor. However, only surfaces directly facing the camera will be projected consistently from shot to shot, and you will have to do some kind of image warping on other surfaces to get them to match. This is because 2-point perspective has two vanishing points located in the horizontal plane of the camera. Surfaces that don't face directly toward the camera taper into the background toward the vanishing points. As you move the camera upward, the vanishing points move upward along with it, meaning that surfaces that are not square to the camera get different perspective in each shot. And again, this is exactly the same effect as you would get with a real camera.
                              To address your second question, due to the way it generates images, SketchUp has no mechanism to create an image with different content than the view.
                              • olisheaO
                                olishea
                                -Keep your camera at a fixed position. Set height to around 1500mm. This is close to a tripod.
                                -Use the "look around" tool to get your first shot at the base of the building
                                -Using the look around tool again, look up slightly and make another render. Just don't look up too much, make sure the images would overlap.
                                -Again, using look around, take another render looking up even higher. The renders should overlap slightly. It could take between 3 and 4 renders to get the whole height of the building.
                                -Using a dedicated panorama stitching app (lots of free ones) you can stitch these images together as long as they overlap. You do not need to use parallel projection or 2 point. Photoshop has a built-in Photomerge plugin that automatically joins together perspective images.
                                After you have done this, free transform the whole image to remove the vertical convergence. πŸ˜‰
                                I use this Photoshop Photomerge process for taking simple panoramas like below. I use PTGui Pro for more complex spherical stitching. There are many to choose from and the process is simple when you get used to it. The process is exactly the same for vertical images. πŸ˜‰
                                http://i654.photobucket.com/albums/uu269/olishea/Untitled_Panorama2_PS_SMALL_zps23b026a8.jpg
                                http://i654.photobucket.com/albums/uu269/olishea/Untitled_Panorama_PS_SMALL_zps5d621b1b.jpg
                                http://i654.photobucket.com/albums/uu269/olishea/Untitled_Panorama3_zpsd9b8a8f0.jpg
                                oli
                                • M
                                  maccabist
                                  Thanks again, so much.
                                  Oli i'll try what u suggest. it seems to be what i need.
                                  πŸ˜„
                                  • olisheaO
                                    olishea
                                    Yes, what I was suggesting is.....it doesn't need to be 2 point or parallel to merge....Photoshop recognises where the images overlap and free transforms/skews them to merge into each other automatically.
                                    As panoramas are normally made in a landscape fashion, you may need to rotate your images before processing them. Basically trick photoshop into thinking it's a landscape when it's actually a building. Hope this makes sense.
                                    The above panoramas were made up of around 5-7 single images.
                                    oli
