    Bend modifier
    7 Posts 4 Posters 723 Views 4 Watching
    • T
      tr000tyl
      Hello
      I am trying to make something like this with the curve texture? What plugin should I use?
      https://lh4.googleusercontent.com/-mDihNFDe7nA/VL0fOTR4nfI/AAAAAAAABQI/aIrotfDzGTw/w400-h200-no/brick-stone-fireplace-install-quotes.jpg
      https://lh5.googleusercontent.com/-hnHCCBfixPM/VL0f34-Y6RI/AAAAAAAABQU/Sl6o7OZX2bo/w502-h334-no/Untitled-1.jpg
      I am looking for a something like SHAPE BENDER but to work on the textures.
      • D
        d12dozr
        Check out Thomthom's UV Toolkit: http://sketchucation.com/plugin/740-tt_uv_toolkit
        http://goo.gl/f7ooYh
        • T
          tr000tyl
          Yes I have it - but I still don't know how to make the curved bricks 😞
          • TIGT
            Mark the center of the arch's arc,
            Select the left side of the arch.
            Use the Rotate tool, centered on the mark and align on the arch face.
            Press Ctrl to go into radial-copy mode.
            Click the selected edge, then the edge of the other side of the arch.
            Immediately type in /N
            • <enter>
              Where 'N' is the number of divisions you require - e.g. 11.
              The arch face is now divided up into separate tapered brick faces...
              You can then UVmap your brick texture onto each one of them as desired [rotate/scale/skew etc]...
            • T
              tr000tyl
              I know how to make this 3d model but I don't know how to make the curved texture.
              • N
                numerobis
                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552
                • T
                  tr000tyl
                  Thanks a lot! It works!
