    [Plugin] 3 point Window
    37 Posts 15 Posters 11.9k Views 15 Watching
    • PixeroP Offline
      Pixero
      A plugin that creates a rectangular window as a component and adds frame and glass material with just three clicks.
      Settings for window inset, frame width, frame thickness, glass thickness and glass inset.
      Choose your window settings, click top left, top right and bottom right corner.
      Download: http://sketchucation.com/pluginstore?pln=3pt_Window
        Nice !
        • K Offline
          kaas
          Nice Pixero. Quite useful. You also incorporated the materials. Is this the final version or do you have more plans with this plugin?
          • PixeroP Offline
            Pixero
            I have some ideas but no time frame. It maybe doesn't have all the bells and whistles but it's one of those scripts that will save time for me and hopefully others as well.
            A good thing is that you can edit the materials and it will be smart enough to use the updated material instead of creating a new.
            Or if you want some windows with different material just rename the existing material and the script will create a new on the next use.
            It also creates the window as a component with a correct axis. Makes it easier to edit and move.
              Ben Ritter
              Thank you Pixero. πŸ‘
                Ben Ritter
                However, I get a Bugsplat every time I use it.
                Windows 7 - 64 bit, SU 8.0.15158
                • PixeroP Offline
                  Pixero
                  Ok I never tested it with SU 8. 😳
                  • PixeroP Offline
                    Pixero
                    Hmm... just tested it with SketchUp 8 and it works without errors for me.
                      Ben Ritter
                      A conflict with another plugin perhaps?
                        agrazdi
                        Mr. Pixero
                        Great plugin, thanks.
                        It would be of a great help to have a 3 point door plugin. ( as simple as this one, for fast proyects )
                        Hope one day you can develope it.
                        agrazdi
                        • brewskyB Offline
                          brewsky
                          I like this! πŸ˜„
                          I got one problem when testing it in SU2015, the glass is placed just outside the window frame.
                          If you could make the window a cutting component, it would work great with my bim-tools plugin πŸ˜‰
                          Cheers!
                          Jan
                          Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
                          • PixeroP Offline
                            Pixero
                            Yes I have found a bug at certain angles and am working on a fix.
                            • PixeroP Offline
                              Pixero
                              It should be under: View -> Toolbars -> 3 point Window.
                              Updated to v1.0.1. Fixed a bug that caused axis problems when drawn at certain angles.
                                DonVid
                                Look nice.
                                I installed it in Sketchup 2014 but I can not find it in plugings list.
                                I also noticed that the the window does not cut the wall (See through the glass).
                                Thank you.
                                Don
                                • PixeroP Offline
                                  Pixero
                                  This version doesn't cut a hole since my preferred workflow is to make walls with holes.
                                  Who knows what the future brings? I have ideas but no time frame.
                                    db11
                                    First off Pixero, thanks for a great plug-in. Its simplicity and speed in custom window creation is awesome.
                                    One thing that slows me down is having to over-write the pre-sets each time I re-open the tool. I was thinking no problem, I'll just open the script and modify the parameters... but it's .rbs not .rb, therefore uneditable.
                                    I would like to set the frame and window dimensions once (based on manufacturer specs for the current project) and have it remember them β€” rather than over-writing with default values on each new use.
                                    So, if you had a way of saving new pre-set values, it would be great. Even better would be multiple pre-sets... for fixed-pane vs operable windows vs window-walls etc.
                                    Request 2 is an option for triple pane windows. (my current projects are both PassivHaus)
                                    I understand not wanting feature-bloat to ruin a simple approach, but each of these features would extend functionality without impeding usability. (though they would obviously make the script itself more complex, so I would understand not wanting to)
                                    Thanks for the consideration.
                                    • PixeroP Offline
                                      Pixero
                                      Remembering settings, it's is on my to do list. πŸ‘
                                        db11
                                        Perfect! Will look forward to upcoming releases.
                                        • PixeroP Offline
                                          Pixero
                                          v1.0.2
                                          Added session memory of settings.
                                            db11
                                            @pixero said:
                                            v1.0.2
                                            Perfect. Makes a great tool even better. Thanks!
                                            • 1 / 2
