    [Plugin] 3 point Window
    37 Posts 15 Posters 13.1k Views 15 Watching
    • PixeroP
      Pixero
      I have some ideas but no time frame. It maybe doesn't have all the bells and whistles but it's one of those scripts that will save time for me and hopefully others as well.
      A good thing is that you can edit the materials and it will be smart enough to use the updated material instead of creating a new.
      Or if you want some windows with different material just rename the existing material and the script will create a new on the next use.
      It also creates the window as a component with a correct axis. Makes it easier to edit and move.
      • B
        Ben Ritter
        Thank you Pixero. πŸ‘
        • B
          Ben Ritter
          However, I get a Bugsplat every time I use it.
          Windows 7 - 64 bit, SU 8.0.15158
          • PixeroP
            Pixero
            Ok I never tested it with SU 8. 😳
            • PixeroP
              Pixero
              Hmm... just tested it with SketchUp 8 and it works without errors for me.
              • B
                Ben Ritter
                A conflict with another plugin perhaps?
                  agrazdi
                  Mr. Pixero
                  Great plugin, thanks.
                  It would be of a great help to have a 3 point door plugin. ( as simple as this one, for fast proyects )
                  Hope one day you can develope it.
                  agrazdi
                  • brewskyB
                    brewsky
                    I like this! πŸ˜„
                    I got one problem when testing it in SU2015, the glass is placed just outside the window frame.
                    If you could make the window a cutting component, it would work great with my bim-tools plugin πŸ˜‰
                    Cheers!
                    Jan
                    Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
                    • PixeroP
                      Pixero
                      Yes I have found a bug at certain angles and am working on a fix.
                      • PixeroP
                        Pixero
                        It should be under: View -> Toolbars -> 3 point Window.
                        Updated to v1.0.1. Fixed a bug that caused axis problems when drawn at certain angles.
                          DonVid
                          Look nice.
                          I installed it in Sketchup 2014 but I can not find it in plugings list.
                          I also noticed that the the window does not cut the wall (See through the glass).
                          Thank you.
                          Don
                          • PixeroP
                            Pixero
                            This version doesn't cut a hole since my preferred workflow is to make walls with holes.
                            Who knows what the future brings? I have ideas but no time frame.
                              db11
                              First off Pixero, thanks for a great plug-in. Its simplicity and speed in custom window creation is awesome.
                              One thing that slows me down is having to over-write the pre-sets each time I re-open the tool. I was thinking no problem, I'll just open the script and modify the parameters... but it's .rbs not .rb, therefore uneditable.
                              I would like to set the frame and window dimensions once (based on manufacturer specs for the current project) and have it remember them β€” rather than over-writing with default values on each new use.
                              So, if you had a way of saving new pre-set values, it would be great. Even better would be multiple pre-sets... for fixed-pane vs operable windows vs window-walls etc.
                              Request 2 is an option for triple pane windows. (my current projects are both PassivHaus)
                              I understand not wanting feature-bloat to ruin a simple approach, but each of these features would extend functionality without impeding usability. (though they would obviously make the script itself more complex, so I would understand not wanting to)
                              Thanks for the consideration.
                              • PixeroP
                                Pixero
                                Remembering settings, it's is on my to do list. πŸ‘
                                  db11
                                  Perfect! Will look forward to upcoming releases.
                                  • PixeroP
                                    Pixero
                                    v1.0.2
                                    Added session memory of settings.
                                      db11
                                      @pixero said:
                                      v1.0.2
                                      Perfect. Makes a great tool even better. Thanks!
                                      • FrederikF
                                        Frederik
                                        This is a nice little gem... πŸ‘
                                        I've found a bug, though...
                                        When making windows in a wall following the X or Y axis (0 degree), it works great...
                                        However, if you have a wall in i.e. a 45 degree angle, the glass planes become offset...
                                        And even if you continue to do it on a 0 degree wall, the offset is all of a sudden twice as big as on the 45 degree wall...
                                        I've attached an image showing what I mean as well as the 'skippy' used for this...
                                        3-point-window-bug.skp
                                        Cheers
                                        Kim Frederik
                                        • PixeroP
                                          Pixero
                                          I just tried your scene but couldn't replicate the error.
                                          What version are you using? The current version is 1.0.4.
                                          • FrederikF
                                            Frederik
                                            That's odd... 😐
                                            I do use ver. 1.0.4 together with SU 2015 Pro on a Win 7 64bit 'puter...
                                            And now I can't replicate it either... 😳 πŸ˜’
                                            Cheers
                                            Kim Frederik
