    Problem installling TT_Lib_v2.9.1.5
    4 Posts 2 Posters 388 Views 2 Watching
    • elmerE Offline
      elmer
      I am having problems installing TT_Lib_v2.9.1.5.
      Here is the message I get
      Thanks for help.
        I'm guessing you are using a OSX version older than 10.7?
        If that is the case you need to stick with an older version - 2.9.10 or 2.9.9:
        https://bitbucket.org/thomthom/tt-library-2/downloads
        (Note - it's not 2.9.1.5 - it's 2.9.15 - the distinction is important because 2.9.15 is newer than 2.9.1.)
        • elmerE Offline
          elmer
          Hi Thomthom,
          Many thanks for that quick reply.
          You are right, I am OSX 10.6.8....
          Thanks again
          That does the job!
            Unfortunately I had to drop support for older OSX versions as it was getting harder and harder to compile for all the OSX versions. I had to update the way I compiled in order to make things work with the latest OSX version.
