    Corrupt SKetchup file
    7 Posts 4 Posters 811 Views 4 Watching
    • G
      geovaf
      hi I'm using Sketchup pro 8 on a mac
      I'm using a file which I think is corrupt, as it is only 22mb and it keeps crashing on opening.
      I tried opening it and importing it into a file with closed dialog windows. what else can i do?
        Perhaps you could try opening it on another computer with the same or a newer version of SketchUp?
        • G
          geovaf
          i've tried that now, and it is still not working - it just opens and then crashes.
          ps. i don't have any back up files or previous versions.
          • S
            slbaumgartner
            Although other causes are certainly possible, the most common source of crash on open is a misbehaving plugin. Have you tried disabling all plugins before opening the file to see if that helps?
            • G
              geovaf
              how do I disable my plugins?
              ps. thank you both for your replies
              • D
                driven
                @geovaf said:
                how do I disable my plugins?...
                rename your "Plugins" folder "Plugins!" [note added "!"]...
                you can find it from 'Sketchup menu' >> 'Window' >> 'Ruby Console'...
                Sketchup.find_support_file("Plugins")
                on v8 it may also be worth checking in the 'Tools' folder for render/stray Plugins, and do the same if any are found.
                john
                • G
                  geovaf
                  Thank you
                  I've managed to open the file by renaming it, and I've purged it and checked for any problems (there weren't any)
                  its a 27mb file and its still abit slow and whenever i put shadows on it crashes, is there any way around this? all repeated objects are already components.
