    How to slice geometry without sections?
    8 Posts 5 Posters 605 Views 5 Watching
    • S
      skavan
      I have a roof (with beams and rafters) in multiple groups. I want to slice off and erase a 3' slice on 2 sides (back and side).
      Pretty easy with a section...but when I export the geometry, I lose the "cut" because the section tool doesn't seem to allow me to "bake" the cut.
      Any ideas? Have searched high and low for a miracle plugin...to no avail. The roof, is NOT a solid.
      I've attached the SU file...would love to get pushed in the right direction - thanks.
      verandah 2008.skp
      s.
      • gillesG
        gilles
        Zorro 2 have a submenu: slice at section.
          Use the Slicer by Tig
          • Add faces by Tig don't make the trick ?
          But I believe that I don't understand what is wished 😳
          Image Before After example will be fine! πŸ˜„
          • KrisidiousK
            Krisidious
            Both of the suggestions given should do as you ask.
            By: Kristoff Rand
            • S
              skavan
              mmmh....it could be that I am missing something pretty fundamental...but:
              1. When I try and use Slicer it tells me thats its not a Manifold Solid and I can go no further.
              2. If I try and use Zorro, no matter what I try, I can't seem to get the "slicing plane" to run vertically. It always insists on cutting through at an angle.
              The first 2 images below shows the before and after that I am looking for (exactly what a section plane would do - but with real impact on the geometry). If it could cut and delete that would be even better!
              The third image shows Zorro - after choosing a cut line exactly on the Red Axis! H-E-L-P!
              • TIGT
                Why not approach this from another direction...
                Try by firstly making the hip-tree beams, and any ridge-board or valleys etc.
                That gives you something to extend/trim to...
                Then, assuming the rafters are raw geometry or individual groups...
                Make them shorter than the span they need...
                Select the end of the rafters.
                Use my Extrude Tools - ExtendEdgesByVectorToObjects...
                Pick the vector, using the magenta 'inference' so that it's parallel to the rafter's length [or make a guide-line earlier on to help you snap]
                Pick well through the target hip-tree etc.
                The ends of the rafter[s] are then extruded to the hip-tree etc, with auto miters as you hope for...
                • gillesG
                  gilles
                  [attachment=3:2l8uco4k]<!-- ia3 -->final cut a.jpg<!-- ia3 -->[/attachment:2l8uco4k]
                  [attachment=2:2l8uco4k]<!-- ia2 -->final cut b.jpg<!-- ia2 -->[/attachment:2l8uco4k]
                  [attachment=1:2l8uco4k]<!-- ia1 -->final cut c.jpg<!-- ia1 -->[/attachment:2l8uco4k]
                  For Zorro you must first insert a section, then right clicking the selected section the submenu propose slice model at section.
                  After this delete the section plane.
                  Note: make this inside group or component or it will slice the entire model.
                  Hope this is what you're looking for.
                  clicliclic
                  • S
                    skavan
                    Awesome -- Zorro (now that I understand how to use it!) did the trick.
                    TIG's method is a bit more elegant - but a lot more work!
