    [Plugin] FredoTools::ElementStats - v1.0a - 10 Jan 15
    5 Posts 3 Posters 8.0k Views 3 Watching
    • fredo6F
      fredo6
      http://forums.sketchucation.com/download/file.php?id=49290
      ElementStats is a standalone script which is part of FredoTools. It provides statistics and information on groups, components and any entity in the model.
      Statistics are given on:
      • The active model (and active context, if within a group or component)
      • The selection (initial, set by the Outliner or interactive selection)
      • The entities under the cursor. Information is displayed in a floating palette
      http://forums.sketchucation.com/download/file.php?id=49287
      ElementStats is installed as part of FredoTools 2.5 and above.
      See the main post for this plugin for Installation of FredoTools
      http://forums.sketchucation.com/download/file.php?id=49286
      (see also section Quick Start and Video below)
      Quickcard ElementStats - English - v1.0.pdf
      • SU Versions: SU6, SU7, SU8, SU13, SU14, SU15 – works better with SU8 M1 and above
      • Platforms: Windows and Mac
      • Languages: English, French
      • Menus: by default, ElementStats is installed in Tools > FredoTools. It does NOT appear in the Contextual menu.
      • Icon toolbar: Fredo6 Tools. There is only a single icon. By default, it is not shown. You need to go to the Default Parameters… dialog of FredoTools to enable the icon.
      • The plugin is free, for private and commercial usage.
      http://forums.sketchucation.com/download/file.php?id=49284
      ElementStats Overview
      http://forums.sketchucation.com/download/file.php?id=49288
      Launching ElementStats
      A button palette window appears. It displays statistics about the model and the current selection.
      [attachment=9:2ki8zdk4]<!-- ia9 -->ElementStats Palette.png<!-- ia9 -->[/attachment:2ki8zdk4]
      [attachment=5:2ki8zdk4]<!-- ia5 -->ElementStats Palette description Model.png<!-- ia5 -->[/attachment:2ki8zdk4]
      Inspecting Entities in the model
      Groups and Components
      Just hover the mouse over groups and components. A floating palette will display information on the entity under the cursor as well as statistics on the container at 4 levels:
      • Current container
      • Current Container and its descendants
      • Direct Parent of the container
      • Top Parent of the container
        [attachment=4:2ki8zdk4]<!-- ia4 -->ElementStats Palette description Grouponent.png<!-- ia4 -->[/attachment:2ki8zdk4]
      Entities
      Just hover the mouse over faces, edges, etc… which are top level of the model or active context. A small floating palette will display information on the entity under the cursor:
      • For a Face, information is also given on the neighbouring surface, if any
      • For an Edge, information is also given on the Sketchup Curve if applicable, including distinction of Arcs, Polygons and Circles
        [attachment=3:2ki8zdk4]<!-- ia3 -->ElementStats Palette Entity.png<!-- ia3 -->[/attachment:2ki8zdk4]
      Displaying Debug information
      This is for developers only. A flag in the default Parameters dialog box allows the display of some technical information: EntityID and Ruby Object address.
      [attachment=2:2ki8zdk4]<!-- ia2 -->Snap13.png<!-- ia2 -->[/attachment:2ki8zdk4]
      Follow-Mouse versus Fixed Information Palette
      You have the option to set the Information palettes to
      • follow the mouse
      • or be fixed (position saved across SU Sessions)
        This is managed by a button in the palette and an option in the Default Parameters... dialog box
        [attachment=1:2ki8zdk4]<!-- ia1 -->Snap10.png<!-- ia1 -->[/attachment:2ki8zdk4]
        [attachment=0:2ki8zdk4]<!-- ia0 -->Snap11.png<!-- ia0 -->[/attachment:2ki8zdk4]
      http://forums.sketchucation.com/download/file.php?id=49289
      ElementStats 1.0a – 10 Jan 15: Initial public release in FredoTools 2.5a
      • F
        Ferrie
        Fredo, nice plugin, but I tried to launch and appears an error popup message, so I can't check on your plugin. Never had a problem with yours, and this is the first one, I imagine it must be in preliminary status as you indicate in "Release Notes" (initial public release).
        I use GSU8Pro and Windows7
        I receive this message.
        Do you have any idea of what or where could be the problem? 😢
        Anyway I love your plugins
          Does exist comparison between groups, components ? (useful after importation from other progs)
          see this post! 😉
          • fredo6F
            fredo6
            [attachment=0:ir6qq8t7]<!-- ia0 -->caption490.jpg<!-- ia0 -->[/attachment:ir6qq8t7]
            Yes. My fault. There are a few changes in how Ruby validate the syntax between 1.8 and 2.0 (and I should remember this one)
            Fix published as Fredotools 2.5c
            Thanks for signaling the problem.
            Fredo
            • F
              Ferrie
              Great plugin!
              Now it works perfectly.
              Thank you fredo.
              Ferrie
