    JOINING OFFSET DUCTS
    4 Posts 3 Posters 381 Views 3 Watching
    • P
      pipingguy
      On the attached file, I generated a step-by-step process for creating an offset that maintains a proper width. But is there a faster way to accomplish this? Curviloft is faster, but the offset piece is partially squashed.
      HOW TO OFFSET DUCTS.skp
      offset elevation view.pdf
        How about just drawing a center line for the ducting and using Follow Me for a cross section of the duct? There's no squashing with Follow Me, either.
        • pbacotP
          Here's my idea. Do you think it's valid? It mainly involves moving one face to correct the height of the angled section. You use push pull with option key (Mac) to make breaks at each end of proposed offset (or copy edges from end of duct).
          HOW TO OFFSET DUCTS 2.skp
          • P
            pipingguy
            Sometimes we overlook the simplest means. Thank you.
