    Export pages in LO not working in SU2015
    layout
    15 Posts 6 Posters 2.4k Views 6 Watching
    • keea1111K
      keea1111
      HI,
      For some reason, since I have been using SU2015, I cannot export specific pages from LO?  If I have an 8 page document and I want to export from page (1) to page (1) from the options button, it still exports all 8 regardless?  Does anyone have any experience with this or could help me out?  thanks, Keea
      KEEA
      • keea1111K
        keea1111
        HI,
        I guess no one else is experiencing this, but I still can't export specific pages in LO. Anyone have any idea or a work around...thanks for your time...Keea
        KEEA
        • pbacotP
          Works for me. It's too bad LayOut doesn't have a decent method to select pages to print, except this old "From __ to__" standard.
          But I'm on a Mac. Fill in your profile for more specific help.
          • C
            Charlie__V
            @keea1111 said:
            HI,
            Not sure why.......but I have noticed on my machine.......the "from" page selection will often revert (to page 1) upon selection of the "to" page selection.
            IOW......if I first select "from" page #3.......and want to only export page #3.........I then select "to" page #3.......when I look back at the**"from"** selection.........It has reverted to page #1.........and after changing this to page #3 (a second time) it will then remain.......and export as I wish
            hope that makes sense.
            C
            • keea1111K
              keea1111
              I tried that, and it is still not exporting the specific page. If I say "to: 3 and from: 3" and press "OK", it will revert to the "all" button, rather than the "from" button. This is really an issue in my work, and wondering if anyone can help me on this. thanks, Keea
              KEEA
              • BoxB
                I have no answer but will point out that your thread title doesn't help to get an answer.
                It reads as if you are telling us there is a new feature you have just found, rather than you have a problem that needs answering.
                I know it's only a typo of W for T but it makes all the difference.
                • C
                  Charlie__V
                  Where are you pressing OK?
                  Enter the page to-from (same page# for single page)......or the page range.... and select export.
                  C
                  export
                  • RichardR
                    Richard
                    @keea1111 said:
                    HI,
                    C
                    I think this has always been the case! You have to input the upper range first! IE it wont let you select range 3 to 1 as 3 is a greater value. You have to input the higher range first!
                    BUILTBRAND.COM.AU
                    • RichardR
                      Richard
                      An export "current page" would be BLOODY handy!
                      BUILTBRAND.COM.AU
                      • keea1111K
                        keea1111
                        HI,
                        Here is an example of what is going on as it is still an issue(see attachment). Any help would be appreciated, because in this example, it is still exporting 4 pages, and all I want is the 1st one. thanks, Keea
                        KEEA
                        • keea1111K
                          keea1111
                          Here is the screen shot..Keea
                          LO screen shot.pdf
                          KEEA
                          • C
                            Charlie__V
                            @keea1111 said:
                            HI,
                            Just a wild azz guess on my part:
                            I see you are on a Mac....no big deal.......but I am not familiar with the interface.... as I am on Windows.
                            That said.......your page #1 is the cover sheet.....correct?
                            This shouldn't matter.......but in case it does.......please try exporting page #2 to page #2 and report back. (please)
                            Maybe there is a glitch of some kind not recognizing the cover sheet as page #1?
                            C
                            • keea1111K
                              keea1111
                              Yes, it does it in any instance I try to export a specific page or pages. I even tried re-installing LO..
                              KEEA
                              • D
                                driven
                                it works fine on Yosemite, but you haven't filled in your profile or said which osx...
                                set range at [4 to 5] first then change to the [5] to a [4]...
                                or whatever page your after, this is very common for all apps on my mac...
                                john
                                • keea1111K
                                  keea1111
                                  Still not working for me! Sometimes it does and sometimes it doesn't. I can't find out why it is not consistent. I'm on Mac OSX 10.9.5...much thanks, Keea
                                  KEEA
