    Export pages in LO not working in SU2015
    layout
    15 Posts 6 Posters 2.1k Views 6 Watching
      Charlie__V
      @keea1111 said:
      HI,
      For some reason, since I have been using SU2015, I cannot export specific pages from LO?  If I have an 8 page document and I want to export from page (1) to page (1) from the options button, it still exports all 8 regardless?  Does anyone have any experience with this or could help me out?  thanks, Keea
      Not sure why.......but I have noticed on my machine.......the "from" page selection will often revert (to page 1) upon selection of the "to" page selection.
      IOW......if I first select "from" page #3.......and want to only export page #3.........I then select "to" page #3.......when I look back at the**"from"** selection.........It has reverted to page #1.........and after changing this to page #3 (a second time) it will then remain.......and export as I wish
      hope that makes sense.
      C
      • keea1111K Offline
        keea1111
        I tried that, and it is still not exporting the specific page. If I say "to: 3 and from: 3" and press "OK", it will revert to the "all" button, rather than the "from" button. This is really an issue in my work, and wondering if anyone can help me on this. thanks, Keea
        KEEA
        • BoxB Offline
          I have no answer but will point out that your thread title doesn't help to get an answer.
          It reads as if you are telling us there is a new feature you have just found, rather than you have a problem that needs answering.
          I know it's only a typo of W for T but it makes all the difference.
            Charlie__V
            Where are you pressing OK?
            Enter the page to-from (same page# for single page)......or the page range.... and select export.
            C
            export
            • RichardR Offline
              Richard
              @keea1111 said:
              HI,
              C
              I think this has always been the case! You have to input the upper range first! IE it wont let you select range 3 to 1 as 3 is a greater value. You have to input the higher range first!
              BUILTBRAND.COM.AU
              • RichardR Offline
                Richard
                An export "current page" would be BLOODY handy!
                BUILTBRAND.COM.AU
                • keea1111K Offline
                  keea1111
                  HI,
                  Here is an example of what is going on as it is still an issue(see attachment). Any help would be appreciated, because in this example, it is still exporting 4 pages, and all I want is the 1st one. thanks, Keea
                  KEEA
                  • keea1111K Offline
                    keea1111
                    Here is the screen shot..Keea
                    LO screen shot.pdf
                    KEEA
                      Charlie__V
                      @keea1111 said:
                      HI,
                      Just a wild azz guess on my part:
                      I see you are on a Mac....no big deal.......but I am not familiar with the interface.... as I am on Windows.
                      That said.......your page #1 is the cover sheet.....correct?
                      This shouldn't matter.......but in case it does.......please try exporting page #2 to page #2 and report back. (please)
                      Maybe there is a glitch of some kind not recognizing the cover sheet as page #1?
                      C
                      • keea1111K Offline
                        keea1111
                        Yes, it does it in any instance I try to export a specific page or pages. I even tried re-installing LO..
                        KEEA
                          driven
                          it works fine on Yosemite, but you haven't filled in your profile or said which osx...
                          set range at [4 to 5] first then change to the [5] to a [4]...
                          or whatever page your after, this is very common for all apps on my mac...
                          • keea1111K Offline
                            keea1111
                            Still not working for me! Sometimes it does and sometimes it doesn't. I can't find out why it is not consistent. I'm on Mac OSX 10.9.5...much thanks, Keea
                            KEEA
