    [REQ] Optimizing plugin
    8 Posts 5 Posters 612 Views 5 Watching
    • PixeroP
      Pixero
      Just asking if it's possible to optimize the plugin; "Convert DWG Layer Names to Materials" to run faster?
      • A
        Aerilius
        Yes it is (uses slow typename and recurses over all entities in the model).
        It applies to each entity a material matching the entity's layer (name, random color). It may depend on the input data whether it could skip some recursion (Does the imported model not have any materials, and are all entities in a component on the same layer as the component?).
        But please, let's clarify first publicly who is going to do it. Is Al Hart here?
        • D
          driven
          Al's is a modified version of this, although it's later update by Didier is a rbs...
          Copyright 2006, Didier Bur
          Permission to use, copy, modify, and distribute this software for
          any purpose and without fee is hereby granted, provided that the above # copyright notice appear in all copies.
          THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
          IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
          WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
          Description : manages layers and materials like the "color by layer" mode
          Author : Didier Bur CRAI-MAP CNRS 694. ENSA Nancy.
          Usage : See below
          Date : 27.Sept.2006
          Type :Tool
          History: 1.0 (27.Sept.2006) - first version.
          john
          • TIGT
            Didier's version is better.
            Al's doesn't claim copyright, but neither does it eschew it - it does recognize Didier's earlier version.
            Didier did agree that I could update/overhaul his scripts that were in the SCF PluginStore, but this one is not.
            He won't be doing much on his own because of work-pressures...
            I might have a go doing my own version...
            What do you think ?
            • PixeroP
              Pixero
              That would be great.
              • TIGT
                I've created a new toolset, which I think does what you wanted.
                It's now in the PluginStore.
                http://sketchucation.com/pluginstore?pln=TIG_layer_material_tools
                • PixeroP
                  Pixero
                  Thanks. I'm out of town for the weekend but I will test it asap.
                  • thomthomT
                    We've been toying with an idea of providing automatic feedback to developers when they upload to extensions to EW. We could scan the RB files and detect use of typename and warn developers of the potential performance hit. The typename usage is the most common performance issue we see around.
