    Detect Linux from the RUBY or Sketchup API
    8 Posts 5 Posters 1.2k Views 5 Watching
    • fredo6F Offline
      fredo6
      Any way to detect the home system on the computer is on Linux, either from the RUBY API or from the Sketchup API?
      The issue I have found is that the ordering of files (so impacting the order of rb files loaded by Sketchup) is different on Linux versus Windows and Mac.
      At least the ! sign is not considered coming earlier than the alpha numeric characters.
      This is a big issue because I assumed that it would be the case. For instance Fredo6_!LibFredo6.rb should load BEFORE any other Fredo6_xxxx rb files.
      Fredo
        The ENV returns some OS specific entries...
        MAC it's TMPDIR
        WIN it's TEMP && USERPROFILE
        LINUX it's USERPROFILE
        So if the user has ENV['USERPROFILE'] BUT NOT TEMP then it's LINUX ?
        • fredo6F Offline
          fredo6
          TIG,
          Thanks very much.
          By the way don't you have the ! problem on Linux with the PluuginStore (!Sketchucation_loader.rb)?
          Fredo
            The initial ! has never been reported as an issue.
            All it would do is load SketchUcation menu later on in the Plugins menu ?
            It's just used to load them first, so they are not lost in a long list...
            I use # for several of my own plugins as that puts them near the top - not sure how that sorts in Linux either !!
              slbaumgartner
              The old standby RUBY_PLATFORM won't work?
                It's likely to mimic Windows setup - I found the ENV way the best trap...
                  driven
                  TextureResizer.rb by Andreas Eisenbarth uses...
                  @platform = RUBY_PLATFORM.include?('darwin')? "mac" ; (RUBY_PLATFORM.include?('mswin')? (!ENV["WINEPREFIX"].nil?? "wine" ; "mswin") ; "other")
                  john
                  • tt_suT Offline
                    tt_su
                    I would place my bets with Andreas - as he use Linux and probably have figured this out. Looking for a Wine related environment variable makes sense since Wine would make SketchUp think it's running Windows - RUBY_PLATFORM wouldn't say linux.
