    Parametric hole making
    10 Posts 5 Posters 2.0k Views 5 Watching
    • john2J Offline
      john2
      I want to make a perforated sheet of metal or anything in sketchup which follows some parametric rules. e.g.
      I have 5 circular holes in a rectangular sheet
      then I make 4 circular holes placed at a specific position calculated with references to the spacing of the 5 ciruclar holes that I made.
      The new 4 circular holes have some mathematical relation of their radii with the 5 circles that I made earlier.
      And so on...I continue to make more circular holes in the sheet. The radii of all those circles are interdependent on all the circles that I made.
      So, if I change radii of one circle, the other circular holes would change in their size accordingly.
      Any trick to do this quickly in sketchup?
      • PixeroP Offline
        Pixero
        Here is a link to a tutorial how to make parametric holes via ruby in SketchUp.
        http://sketchupfordesign.com/the-book/chapter-6-creating-geometry-using-ruby-scripting/
        • john2J Offline
          john2
          Actually I am an architect. So, very bad with scripting an all. Is it possible to make a plugin or something out of this script? Please understand, I have a really hectic schedule and learning new code or language would be really stressful. 😳
          • cottyC Offline
            cotty
            Sounds like a task for a dynamic component, but I wouldn't call it a quick solution...
            my SketchUp gallery
            • jeff hammondJ Offline
              jeff hammond
              do you have a clearer example of what the outcome should be? (other than.. i have 5 holes which determine 4 holes.. etc.)
              dotdotdot
              • john2J Offline
                john2
                Well, I'm in the process of brainstorming design ideas, much like what Zaha hadid does using parametric software like Rhino, etc.
                One thing is a perforated wall with lots and lots of holes which gives a dynamic and scattery scattery look, [pardon my words], that is given on the page suggested by Pixero sir. πŸ‘ πŸ‘
                Thanks a lot for the food for thought!! Hey!! rhyming πŸ˜„ πŸŽ‰ πŸ˜„
                Another one which has got me even more excited is how the walls change their angles if one of the walls is made to change its angle of inclination. It is also given on the same page, which Pixero Sir posted.
                What my ambition to make in sketchup is actually in this video, a great TED talk by Greg lynn explaining organic algorithms in the field of architecture.
                  Look at the SUforyou plugin! πŸ˜‰
                    jeff hammond
                    tbh, 'like rhino' in sketchup only goes so far.. if you want to do what Zaha does, use rhino πŸ˜‰
                    see example..
                    but yeah, i think it might be better to approach this type of stuff in sketchup from a sketchup point of view instead of a math point of view.. for the user, sketchup isn't very math driven at all so maybe don't try to force math on it..
                    (unless you want to learn ruby to do it.. but for me personally, i'd rather spend time learning rhino&grasshopper than learning ruby πŸ˜‰ )
                    yeah, i think you can get the gist of what he's getting at in sketchup.. just not via calculus..
                    Array of cones and a curviloft skin
                    Drop (smustard) cones to skin
                    Place flat plane in cone array
                    Intersect
                    Push Pull
                    dotdotdot
                      jeff hammond
                      here's a similar experiment i did around four years ago..
                      it uses spheres with chrisfullmer's 'component onto faces' then joint push pull..
                      sketchup was pretty much dead with this geometry.. use squares instead of circles if you're going to be trying this stuff πŸ˜‰
                      dotdotdot
                        Tricky steps of cones! πŸ‘
                        But some efforts for the same result than shown on my previous video!
                        (and you can't modify the result of the holes by editing a component! πŸ˜‰
                        ...Try the SuForyou plugins above! πŸ˜’
                        Very powerful and versatile! 😎
                        http://s6.postimg.org/5kuubufgx/suforyou.jpg
                        Some fractal forms πŸ’š
                        http://s6.postimg.org/50y6s4frl/simili.jpg
                        http://s6.postimg.org/ujv4ivopd/simili1.jpg
                        and others concepts
                        http://s6.postimg.org/7g8hp0e35/suforyou2.jpg
                        http://s6.postimg.org/gdt7md6j5/suforyou3.jpg
                        Very pleasant plugins! β˜€
                        Zaha recommends SuForyou! πŸ’š
