    Back up files
    4 Posts 4 Posters 469 Views 4 Watching
    • A
      Ands43
      Hi, When I save my drawings I get one file for example
      SketchUp.skp and another file SketchUp~.skp
      Is there anyway I can get the ~ file to save to another place as it's cluttering up my folders. πŸ˜›
      Thanks Andy
      • U
        unearthed
        Don't you mean .skb file extension - I've found it's NOT a good idea to delete .skb files.
        also see http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=36969
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
        • jeff hammondJ
          jeff hammond
          from within sketchup? no, they'll save in the same place the main file is saving to..
          you could right a little automator workflow which helps tidy things up or maybe the simplest way is to do a finder search for ~.skp then move them all somewhere..
          with a little more specifics of how you'd like them to be organized, someone could possibly show you a way to automate it.
          dotdotdot
          • D
            driven
            ~.skp is the MAC equivalent of PC's .skb - it's the backup file...
            personally, I have them turned off in Preferences, so they don't clutter anything, and Autosave, I only use occasionally...
            but I 'Apple S' [save] regularly...
            why?
            it seems the occasionally SU will attempt to do all 3 at once, updating the ~.skp, the Autosave-.skp and the .skp,
            it takes a disproportionate amount of time on even a simple model...
            the more Plugins with 'Observers' or open 'Panels', the longer this will take...
            I can redraw my changes with a fresh eye quicker than that, so I use 'Save' instead...
            I do occasionally come unstuck...
            I don't recall any way of setting it to a different folder...
            john
