    SU 2015 drawing line problem, not finding endpoints
    3 Posts 2 Posters 659 Views 2 Watching
    • O Offline
      onthescene
      I am having a problem with SU 2015 Pro 64 bit. SU is not finding endpoints for line segments. This is frustrating trying to draw new lines from an intersection or endpoint of previously drawn lines. Any thoughts?
        Have you tried switching Model Info > Units > Length snapping OFF ?
        What is the 'scale' of your object ?
        Very small dimensions ??
        • O Offline
          onthescene
          Thanks TIG. Length snapping was off. I was working in a normal Architectural scale, not micro small objects.I realize one can only zoom in so far. I have experienced problems in older versions, sometimes really large, complex models that caused similar issues.
          My best solution was to save file. Then reopen. No problem after that. Perhaps a plugin I used caused the strange behavior. Thanks for the advice and tips.
