    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    DC nested logical function
    7 Posts 2 Posters 1.8k Views 2 Watching
      dieter10
      Hello,
      This doesn't works in sketchup:
      IF( (length >=50)&&(with<=20),......)
      The problem:
      How do I need to solve this?
      • P Offline
        pcmoor
        there is no "&&" function but "AND"
        use =IF(and(leng >=50,with<=20),true,false)
        or can use nested
        =IF(leng >=50,if(with<=20,true,false),false)
        which returns 0 or 1
        true or false can replaced for any other outcome
          dieter10
          Thanks for the quick reply!
          And i have also some troubles with redrawing.
          Can i make something that if i press the apply button that it automaticly redraws ?
          • P Offline
            pcmoor
            by using the "current" in a dummy variable you may achieve what you are after
            aX = current("x")
            can post the DC, or private message ?
              dieter10
              My model is nearly finished.
              Thanks for the reply's. Conclusion: you just need to think a moment how you're going to solve the problem and how you are going to create the formulas.
              In the .gif file, you can see how i can modify the model.
              But sometimes there is something that doesn't moves or ...
              Is that a bug in sketchup? I never had this problem whem i'm starting from the original model.
              • P Offline
                pcmoor
                You would need to post the DC, so one can check for the error, otherwise look for the red # when it fails, or maybe a redraw is required.........one can only guess
                  dieter10
                  Thanks for your reply pcmoor, i found 2 red #. The function of the subcomponent referred to a variable of another head component. And i forgot to define the x position of 2 pieces. Now it seems to work fine. I just need to add the position for the keys, because they are scaled with the door panel and i want them always off the same distance off the side.
