    DC nested logical function
    Scheduled Pinned Locked Moved Dynamic Components
    7 Posts 2 Posters 2.3k Views 2 Watching
      dieter10
      Hello,
      This doesn't works in sketchup:
      IF( (length >=50)&&(with<=20),......)
      The problem:
      How do I need to solve this?
        pcmoor
        there is no "&&" function but "AND"
        use =IF(and(leng >=50,with<=20),true,false)
        or can use nested
        =IF(leng >=50,if(with<=20,true,false),false)
        which returns 0 or 1
        true or false can replaced for any other outcome
          dieter10
          Thanks for the quick reply!
          And i have also some troubles with redrawing.
          Can i make something that if i press the apply button that it automaticly redraws ?
            pcmoor
            by using the "current" in a dummy variable you may achieve what you are after
            aX = current("x")
            can post the DC, or private message ?
              dieter10
              My model is nearly finished.
              Thanks for the reply's. Conclusion: you just need to think a moment how you're going to solve the problem and how you are going to create the formulas.
              In the .gif file, you can see how i can modify the model.
              But sometimes there is something that doesn't moves or ...
              Is that a bug in sketchup? I never had this problem whem i'm starting from the original model.
                pcmoor
                You would need to post the DC, so one can check for the error, otherwise look for the red # when it fails, or maybe a redraw is required.........one can only guess
                  dieter10
                  Thanks for your reply pcmoor, i found 2 red #. The function of the subcomponent referred to a variable of another head component. And i forgot to define the x position of 2 pieces. Now it seems to work fine. I just need to add the position for the keys, because they are scaled with the door panel and i want them always off the same distance off the side.
