    TOM DIXON LIGHT TEST - HELP
    renderpluginsextensions
    9 Posts 3 Posters 763 Views 3 Watching
      agentorange
      Looking for some help regarding a sphere light within a glass sphere - producing light blotches.
      Unsure what is going on and how to achieve the proper effect. Im using the latest Vray and the glass dome is the Basic Glass from the chaos web site.
      Any help would be appreciated.
      Regrads,
      Aentorange
      • andybotA Offline
        andybot
        as a quick test, delete your refraction layer in your glass and try rendering. It looks like the refraction depth is too low and your direct light is not "escaping" the glass enclosure.
          agentorange
          Cheers for the advice, tried that but still have the dreaded light blotches.... Nice disco ball effect though
            rv1974
            disable Caustics, uncheck reflective GI Caustic, check on sub-pixel mapping and Clamp output.
            • andybotA Offline
              andybot
              do you have caustics on? Do you have any emmissive materials?
                agentorange
                No emmisive materials used and caustics aren't on.
                The light is set very high and obviously will need to add some extra lighting to the scene.
                • andybotA Offline
                  andybot
                  why is your light intensity 100000? 😲
                    agentorange
                    Good question... It was 30000 but wasn't doing much so whacked it up just to get some idea of light in the room
                    • andybotA Offline
                      andybot
                      try running the rendering with the glass dome hidden. Maybe do a material override render too. Something is not right with your GI calculation.
