    SketchUp 2015 is 64bit
    302 Posts 74 Posters 55.0k Views 74 Watching
    • hellnbakH Offline
      hellnbak
      @bob james said:
      As I mentioned in an earlier post in this thread, Nudge **does **work in SU2015. The version I have is nudge.rb 1.5 dated 2008. To be really sure, I just verified it again.
      Here's what I have a question about - I thought plugins had to be .rbz, I was under the impression that old .rb types wouldn't work in 2015. If your Nudge version is indeed an .rb, how did you install it?
      • BoxB Offline
        Drop it in the plugin folder.
        Found at C:\Users\YourUserName\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
          What made you think plugins had to be .rbz? The .rbz file is simple a zip file with a an extension setup so it can be recognized by the Install Extension tool. It will contain at least a .rb file and depending on the plugin, it may contain one or more sub-folders. This has been explained on these forums many times.
          Installing a plugin with the .rb extension can be done in the "old fashioned" way by dropping the file into the Plugins directory (which is located in a different place than it was for SU8 and earlier) or, you could use a zipping utility to add it to a zip file, change .zip to .rbz and then use Install Extension. Changing the .zip to .rbz will work for most any plugin downloaded in the zip version, too.
          • AndrewSA Offline
            AndrewS
            @jeff hammond said:
            aww.. i started reading that as the rest of the sketchUp core team got too high to....
            πŸ’š
            was hoping for something a bit more gossipy
            πŸ˜† Getting high would make work a lot more interesting, but were that part of our regular development practice, I'm not sure we'd have ever gotten around to fixing the shadow bug, let alone going to 64-bit.
            Come to think of it, maybe when our users get too up in arms about the SketchUp x+1 feature list, we should just raffle off a few trips to one of the places where they can legally go chill out. πŸ˜›
            Andrew
            Andrew S.
            SketchUp Release Engineer
            • john2J Offline
              john2
              @dave r said:
              @john2 said:
              All the plugin gods on this forum. Can we have a list of plugins which will not work in the 2015 version of sketchup or which will certainly won't be updated because their creators are no more interested in their future development? πŸŽ‰
              You might take a few minutes to have a look around. This is already in progress in the Plugins forum.
              Apologies for repeated post..
              Sent from my IQ 446 using Tapatalk
              • hellnbakH Offline
                hellnbak
                I was mislead
                Yes, I know. Please keep in mind that I am a noobie as far as the newer versions of SU. And as I said, I was mislead about the plugin extension needing to be .rbz rather than .rb for those newer versions.
                Thanks for the info, Dave. Much appreciated.
                Now, a couple more questions.
                Any way to get rid of this screen -
                and just go straight into the program? Not a huge deal, just a tad annoying.
                And finally, the thumbnails for models saved from 2015 are huge. I love them. So far I have been saving my work as R8 models, until I am certain that 2015 is going to be the version I will be using from now on. However, I just saved a model as 2015, just out of curiousity, and it's thumbnail was back to the regular size. Why is that, and is there any way to make the thumbnails from previous R8 saves this much larger size? Probably not, but you never know until you ask.
                I apologize if these questions have been answered in other posts, but searching for something in the forums can be very iffy unless you happen to use the right search phrase. Please bear with me, and thanks in advance for your help.
                • KrisidiousK Offline
                  Krisidious
                  I think buying pro gets rid of that screen. annoy-ware
                  By: Kristoff Rand
                    Krisidious
                    I would check to see if you have save thumbnail with every save is checked in model properties.
                    I'll be your personal Sketchup help assistant in all your questions as along as I get to see more of your work.
                    By: Kristoff Rand
                    • N Offline
                      numerobis
                      @jonfar said:
                      so my navigation lag is due to my system being an APU?
                      I think its related to both components of the APU, but maybe more on the GPU side in this case...
                      If you compare the A10-5800K to an i7 4770K for instance, you can notice that it has roughly half the performance in many single threaded benches: http://www.anandtech.com/bench/product/675?vs=836
                      38% slower in cinebench:
                      http://www.tomshardware.de/charts/cpu-charts-2013/-01-Cinebench-11.5,3142.html
                      And if you look at the GPU part of the chip it is only a Radeon HD 7660D with 700MB VRAM http://www.videocardbenchmark.net/video_lookup.php?gpu=Radeon+HD+7660D (Passmark 793 - only a rough estimation, because this is not an openGL test but it should be in this range).
                      The FutureMark score looks a bit better: http://www.futuremark.com/hardware/gpu (no.99, 2620)
                        @hellnbak said:
                        I was mislead
                        I wonder who did that.
                        [attachment=0:345wpt9u]<!-- ia0 -->2014-11-05_102149.png<!-- ia0 -->[/attachment:345wpt9u]
                        As Kris said, buy the pro version. You can then turn it off. Seeing it is a very small price to pay for using the free version.
                        I don't see thumbnails for SKP files as any larger than any other thumbnails in the Windows Explorer. Perhaps that's a setting change you need to make in the Explorer window?
                        • tt_suT Offline
                          tt_su
                          @JonFar: What does your OpenGL preferences in SU look like? I have nVidia card on my private computer and I have noticed that on fresh install I tend to end up with AA settings which isn't listed in SU's Preferences. In fact it looks like the AA is higher than the 4x SU offer. While it looks nicer I always felt it didn't perform as well. After switching AA to 4x and restarting it was working better. Just a stab in the dark here.
                          • tt_suT Offline
                            tt_su
                            @numerobis said:
                            But copying geometry could be improved... πŸ˜‰
                            Yea - we really want to improve geometry creation. The FaceFinder improvements in SU2015 was one step into that.
                            • hellnbakH Offline
                              hellnbak
                              Not sure what you mean by this, Kris. I've checked all through Preferences and Model Info, can't find anything like you describe.
                              I agree. Not a big deal, just thought I would check. Usually with something like this you have the option of checking a box if you don't want to see the screen on startup.
                              Yeah, I checked all my options there. No change. Here's an example of what I'm talking about with the thumbnails -
                              The one on the left is the normal size thumbnail I've always been getting. The one on the right is the new and improved larger size I'm getting now. For some reason I'm now getting this larger size even if I save it as a 2015 model. Before I would get it only if I saved it as an R8 model. Go figure. It's clipped on both sides, but shows a lot more detail. I'll live with it πŸ˜†
                              Wow, I never had a personal assistant before. Now, will I be paying you per help instance, or will you be expecting a salary?
                              • jason_marantoJ Offline
                                jason_maranto
                                I did say that if SketchUp Pro got 64-bit that I would definitely buy it -- so it is time for me to put my money back into SketchUp Pro.
                                Best,
                                Jason.
                                • BoxB Offline
                                  Hellnbak, in Model Info/File there is a tick box for redefine thumbnail on save.
                                  If you have that set then your old thumbnails will update to the new larger size whenever you open and resave them.
                                  It can cause a slowdown when saving, but that was in the older versions, it may not be the case in SU2015.
                                    Krisidious
                                    Best,
                                    Jason.
                                    Been dying to see your post on the whole 64 now thing...
                                    By: Kristoff Rand
                                      Krisidious
                                      You can pay me in incredible models to look at and be inspired by...
                                      By: Kristoff Rand
                                        jason_maranto
                                        I got what I wanted (even if there is still grumbling in this thread from Trimble people regarding doing it). Fair is fair, they did what I required, so it is time for me to uphold my end.
                                        Where it goes from here is anyone's guess... but at least I can justify this upgrade fee. I still don't like the attitude -- but as long as they do what is needed to keep the software competive they can be grumpy all they like.
                                        Best,
                                        Jason.
                                        • G Offline
                                          Glenn at home
                                          @hellnbak said:
                                          Don't know if SU2015 will be a big success or another Windows 8, but at least it is breathing new life and an air of excitement back into the forums.
                                          And after the (IMO) lackluster attempts at taking SU forward with R13 and 14, my fears for Sketchup's future after Trimble are now somewhat laid to rest.
                                          They seem to be getting serious about making changes that really matter.
                                          Kudos, Trimble πŸ‘
                                          I have to agree with you on this.
                                          • JonFarJ Offline
                                            JonFar
                                            thanks for the sugestion, but no, there is no visible change and i tried all the listed options
                                            but dont worry about that, as the guys said, i have an APU, i cant expect it to perform like it an F1 racing car πŸ˜„
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 15
                                            • 16
                                            • 7 / 16
