    SketchUp 2015 is 64bit
    302 Posts 74 Posters 96.5k Views 74 Watching
    • JonFarJ Offline
      JonFar
      yes, of course...
      Gigabyte F2A88XM-DS2
      AMD A10-5800k (quadcore at stock speed 3.8ghz and turbo at 4.1ghz)
      Radeon HD 7660D (part of the APU, with 720mb)
      2x GSKILL PC3-17000 CL11 (8Gb in dual-channel @ 2133mhz)
      WD CAVIAR BLUE 7200RPM 16MB SATA III
      CORSAIR VS 450W
      i know its not a high end system, but i shouldnt have any navigation lag with that 47mb model with less than 2000 edges...
      and whats strange is that i get the navigation lag and my system is almost running idle, with only one core working full speed and a fraction of the ram being used
      i thought it was a 32bit issue, but its exactly the same with SU 2015
      (oh, and every other app like C4D or AutoCAD work fine, both 64bit of course)
      here is the model info
        mcpcorey
        Hey Guys, I am trying out 2015 here. I have not yet loaded any of my plug-ins yet, because I notice right away that my 3DConnexion Space Mouse Pro, will not yet work in SU 2015. (never realized how dependent I had become on it, until I tried to work without it!)
        I reloaded the most recent drivers, but no improvement for 2015, still works fine in 2014!.
        I would guess that 3DXware needs a driver update to be compatible with 2015 and the 64 bit application?
        I did send a note / tech request this morning to 3DConnexion regarding this.
        Has anyone had success with a 3DConnexion device in SU2015 ?
        Corey
        • jeff hammondJ Offline
          jeff hammond
          [attachment=0:26eb8lrv]<!-- ia0 -->2.jpg<!-- ia0 -->[/attachment:26eb8lrv]
          click the box 'show nested components'
          I'm thinking the model is in the hundreds of thousands entities range.
          dotdotdot
          • JonFarJ Offline
            JonFar
            sorry, forgot to do that..
            you are right, as always
            but even so, i thing its strange that i get this navigation lag with my system running idle... shouldnt it be using all 4 cores and a bit more RAM than the 2014 SU?
            • K Offline
              kaas
              600k edges and 300k faces might be too much for embedded gfx? Ever tried putting a gfx-card in your system? The fact SU is now 64 bits doesn't mean it will use more than 1 core. That's something totally different.
                jeff hammond
                [attachment=0:2mjb4eyu]<!-- ia0 -->3.jpg<!-- ia0 -->[/attachment:2mjb4eyu]
                fwiw, your model is what i personally consider 'a huge sketchup model'.
                i don't think ram has anything to do with navigation speed.. (well, i imagine it's part of the process.. just that the ram provided with 32bit is plenty to keep up with the other calculations which must occur.. as in- the available ram of an average computer was never a bottleneck in the navigation speed)
                re: multicore.
                should it be using all 4 cores? i really don't know.. up til a few weeks ago, i've always thought a program couldn't use more than one core for things like navigation/redraw..
                but it appears michael gibson of MOI3D has found a way..
                MoI, 3D modeling for designers and artists
                MoI is a new 3D Modeling/CAD application for designers and artists. Offering a blend of precision and freeform NURBS drawing tools, it sports a unique user interface that operates seamlessly with a pen tablet.
                (moi3d.com)
                Multiple CPU cores are now used in the draw engine, typical display speed-up of around 2x to 3x on complex models.
                dotdotdot
                • JonFarJ Offline
                  JonFar
                  hmmmm i see...
                  so my navigation lag is due to my system being an APU? if that's a GPU issue, i can understand
                  and i will look into that michael gibson's findings
                  sorry for clogging this thread with my issues, i just wasnt understanding why you guys had such great improvement in performance and i didnt...
                  i guess i need to invest in a more powerfull machine 😐
                  thanks guys for your help and patience 👍
                    @mcpcorey said:
                    ... because I notice right away that my 3DConnexion Space Mouse Pro, will not yet work in SU 2015.
                    This has already been covered. They are working on an updated driver package. Check the manufacturer's site.
                      mcpcorey
                      Thanks Dave, That is what I suspected, (I knew you would have that answer)
                      I missed where it has already been covered, and I cannot find any reference to it at their web site.
                        jeff hammond
                        @jonfar said:
                        hmmmm i see...
                        well, nobody's machine, no matter how good or expensive, is going to run that model much(if any) better than you're seeing.
                        I'm not sure how 3.8ghz AMD translates to intel clock speed but I assume it's decently fast.. you just can't buy faster processors. they're not available.. but sketchup was written at a time when clock speed was doubling every couple of years so for a while, you could upgrade your hardware and get noticeable performance gains in sketchup.. that quit around 6-7 years ago.
                        dotdotdot
                          jeff hammond
                          I'll also add..
                          you have to be weary when hearing 64bit sketchup has improved performance.
                          while "the new 64bit version of sketchup is faster than the previous versions" may be a true statement, it doesn't mean 64bit is the reason for the increase in performance. there are other (code) optimizations which happen with (nearly) every release which improves performance.
                          thing is, the team hasn't come across the magic bullet which makes performance gains incredibly noticeable. (ie.. 500,000 model now performs like it were a 50,000 entity model).. not sure if they'll ever be able to do that or if it's even possible to begin with.
                          dotdotdot
                          • JonFarJ Offline
                            JonFar
                            maybe my models make my judgement biased, because i always work with those "huge" files, and just switch off layers or hide stuff so that i can navigate better
                            i cant hide my dissapointment, cause when i saw "Sketchup 64bits" i thought i was gonna be able to work with high poly trees and objects like i do with C4D
                            but dont get me wrong, i am very pleased with this new version of SU, it has many other great new features, and its way faster opening, saving, exploding, move-copy, etc
                            • Dan RathbunD Offline
                              Dan Rathbun
                              @al hart said:
                              The SketchUp description of 64 bit says: "The exception to this 32-bit status is that SketchUp for Windows has been built with an exception to allow 64-bit memory usage which allows SketchUp to use more than 4 Gb of RAM."
                              http://help.sketchup.com/en/article/3000069
                              DO you think the second use of the word exception is a mistake, or do you think SketchUp found a way to create a "pseudo" 64-bit - which uses more memory, but isn't really recompiled for 64 bits?
                              Ignoring the fact that this refers to SU2013 & 2014...
                              ... I agree with Al. The second instance of "an exception" should be replaced with "a compiler directive" ...
                              Regarding the link from the 2015 "What's New" page. It should have a anchor added to the URL such that:
                              http://help.sketchup.com/en/article/3000069#SketchUp%202015
                              will select the correct content.
                              I'm not here much anymore.
                                It has been brought up many times since it was first requested that making SketchUp a 64-bit application wouldn't have any impact on the performance issues as you're expecting. As Jeff pointed out, there were code optimizations that do improve performance but on very large, very high poly models, the difference might not be that noticeable because were aren't talking orders of magnitude increases.
                                • BoxB Offline
                                  Plus a lot has to do with your Graphic card, which I mentioned in this post http://sketchucation.com/forums/viewtopic.php?f=10%26amp;t=59650#p543129
                                  • N Offline
                                    numerobis
                                    Ok i have installed it now in tried a 212MB file with 3.2M edges and 4500 components and i can see a big improvement in load and save times 😄 :
                                    v8: loading 1min31sec / saving 5min28sec
                                    v2015: loading 21sec / saving 54sec
                                    (without scene thumbs)
                                    Duplicating geometry (3M edges) in this scene is slower for me in v2015 😲 : ~52sec vs ~40sec in v8
                                    Shadow rendering is much faster! Navigation without shadows is not noticeable faster, but runs fluently in both versions.
                                    another scene (198MB - 1M edges - 600 comp definitions, 4600 instances, 1300 groups)
                                    v8: loading 1min39sec / saving 4min1sec
                                    v2015: loading 9sec / saving 18sec (!)
                                    (i7 3930K@4.7GHz, GTX 560 TI 2GB)
                                    So thank you for this update! 👍
                                    But copying geometry could be improved... 😉
                                    • AndrewSA Offline
                                      AndrewS
                                      @al hart said:
                                      Thanks Andrew - I had seen the warning - but still I assumed I was in the right place, since I had gotten there by clicking on the link in the SketchUp 2015 What's new article.
                                      Al,
                                      We're pretty excited about how the new knowledge/help center allows us to post different articles for each SketchUp version all under one heading, but the events of this week have also made us aware of how it still needs to be improved. At present, we use a cookie to decide which version of content to show you by default. I don't remember how that cookie gets set, but it's essentially created the first time you come to our help site and indicate which version of SketchUp you're using. The problem becomes trying to understand under what circumstances to change the cookie to reflect a new version. We hope to come up with something better one of these days.
                                      Andrew
                                      Andrew S.
                                      SketchUp Release Engineer
                                      • AndrewSA Offline
                                        AndrewS
                                        We worked for YEARS to dispel the notion that 64-bit SketchUp == faster or more cores. If you go back and read everything our team said about 64-bit migration years ago, the theme was essentially, "by and large, people don't need 64-bit; it's not going to get you anything--unless you do activities that cause you to exhaust your memory, like rendering." We beat that drum over and over and over, but people didn't listen. Now we provided 64-bit and it works exactly like we said it would and people are surprised.
                                        Take that thought a little further and consider the atmosphere of us discussing this in the planning meetings over the last few years. Someone says, "Hey, guys, I've got an idea! Let's devote the entire engineering team for months on end to implementing a 64-bit SketchUp. What it gets us is something that 98% of our customers don't need, and it'll completely tie up our team to the point where we'll be able to implement precious little else during the major development cycle, but we should totally do it. Because...64-bit!!!"
                                        We only managed to convince ourselves to do this once we got to the point where a) more of our users started to be affected, b) we could be sure we wouldn't need to support 32-bit on Mac anymore, c) we had enough momentum on this to get it done a little faster than we thought, and d) the rest of the SketchUp core got to high enough performance that we could actually leverage additional memory in a usable way (in the past, SketchUp would often fall to its knees for other reasons before exhausting memory).
                                        Nevertheless, here we are. 64-bit SketchUp. Everything you wanted, but not what most people needed. 😛
                                        Andrew
                                        Andrew S.
                                          jeff hammond
                                          aww.. i started reading that as the rest of the sketchUp core team got too high to....
                                          was hoping for something a bit more gossipy
                                          dotdotdot
                                          • JonFarJ Offline
                                            JonFar
                                            Andrew,
                                            by all means, dont take my posts as criticism
                                            i am just another tipical user, without IT knowledge, who thought 64bits = better performance
                                            when i say that im dissapointed, its not dissapointed at SU 2015 and your team... not at all!! the new version has great new features that will help us a lot!
                                            im dissaponted to find out that 64bits is not the magical powder that makes software run faster...
                                            keep up the good work, cause we'll always be here to demand more and more in each new version 😆 😆 😆
                                            • 6
                                            • 7
                                            • 8
                                            • 15
                                            • 16
                                            • 6 / 16
