    Import DWG file
    15 Posts 5 Posters 1.3k Views 5 Watching
    • ntxdaveN
      ntxdave
      I am importing a DWG file into SU but I do not see all of the details. I have a PDF version of the file that shows tons of details that I cannot see in SU after importing the DWG file.
      Is there some type of setting that I am missing or is this the standard behavior?
      I can understand that when I import the DWG file, it pulls all of the pages into a single view in the viewport but I thought I should be able to see everything in the DWG file.
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        Perhaps I used a bad title or I am just the king on no responses
        I am still wondering if I am doing something wrong when I import a DWG file. I only see partial contents. As an example, I imported a DWG file of a building where I wanted to then add/show some contents. The building detail does not all show. In some parts of the building I had to add lines to "complete" the drawing.
        Is this normal or is there something I can do to get more detail to show in SU?
        • andybotA
          andybot
          Can you open the dwg file? Check to make sure that everything you want to import is in model space, also that there are no missing (or not bound) xrefs.
          • cottyC
            cotty
            It's hard to search for a solution without the file, an image, ... if it's a not so usual probem.
            my SketchUp gallery
            • ntxdaveN
              ntxdave
              Point well taken.....I do not have permission to share the file though.
              • ntxdaveN
                ntxdave
                SU will not let me open it - only import it.
                SU is the only software I have. I have seen this with other DWG files people have sent me to look at as well.
                • andybotA
                  andybot
                  You can perhaps install TrueView (free viewer from Autodesk) and then you can see the dwg file in its original format. I was not suggesting you open the file with SU, my point here is that there can be information in a dwg file that SU doesn't recognize.
                  • K
                    kaas
                    Have you tried changing the import scale settings in Sketchup? Maybe the details are merged into 'nothing'.
                    If you do have a pdf you could also convert the pdf to dxf using Inkscape and import the dxf into Sketchup.
                    • ntxdaveN
                      ntxdave
                      Only option I saw was to change to inches which did not do anything to solve the problem.
                      I started installing Inkscape and got all kinds of garbage so I stopped the installation. Anyone aware of any other software that can make the conversion?
                      • ntxdaveN
                        ntxdave
                        OK - I got a "clean" install of Inkscape and was able to make the conversion from PDF to DXF. I then imported the DXF and yes, I CAN now see all of the detail. Just one problem, the scaling does not match. When I use the tape measure tool in SU, it comes up with an entirely different measurement than what is shown in the PDF/DXF file.
                        Any suggestions on how to change it so that I can use it with the proper dimensions?
                        Just to let you (and anyone else reading this thread), this is a great step forward and I really appreciate the suggestion of converting via Inscape (which looks like an interesting tool on its own).
                        • cottyC
                          cotty
                          Use the tape measure tool for a known length in your model, enter the correct length in the VCB and confirm the dialogue...
                          my SketchUp gallery
                          • ntxdaveN
                            ntxdave
                            PERFECT
                            Now I am "off to the races". I really appreciate the assistance on this forum. I have been using SU for slightly over a year now but keep learning new stuff every day. Do not know how you guys know all of this stuff........I am not an engineer and have no other CAD related background. Find that I have leaned enough to accomplish what I have needed to so far but there is SO much more!!
                            • cottyC
                              cotty
                              Try to answer every question here for some years and you will see that this isn't a problem anymore πŸ˜‰
                              my SketchUp gallery
                              • K
                                kaas
                                We all run into the same problems (with importing files / SketchUp / etc) and for most of them, multiple solutions already have been found in the past here on the forum. Just passing the info along...
                                • J
                                  JGA
                                  SketchUP will not import some DWG information such as text, hatching dimensions, complex surfaces or dynamic blocks. Also, any information on the layouts are ignored.
                                  Finally, curves are faceted when importing to SKUP.
                                  Regards,
                                  JGA
