Can you change the material but keep UV?
I've searched for this everywhere but haven't found an answer. Is it possible to change the material on trimesh and preserve UV texture coordinates in sketchup? I haven't used sketchup in a couple of years and I cant remember if this was possible.
Yes you can, but the new mat should be already in the model:
right click on a face with a mat applied-->entity info-->click on the little mat icon on the left-->scroll the list in the paint panel and pick the new material-->click ok.Of course if you want to change more faces at once you have to select all faces with the same mat before:
right click on a face-->select-->all with same material.
Remember that this kind of selection works only with ungrouped geometry or inside a context. -
Fredo6s ThruPaint (part of FredoTools) has a tool for this:
Register LoginAdvertisement
