    Irradiance map difficulties
    renderpluginsextensions
    4 Posts 2 Posters 511 Views 2 Watching
      ARNEN
      Hello guys ,
      hope you are all ok ,
      im having some troubles with the irradiance map on vray
      even though the min rate is -3 and the max one 0, after the light catche vray still makes just 1 pass ...
      im using irradiance map as primary engine and light catche as secondary...
      any idea whats happening? i did my best but still no result
      • andybotA Offline
        andybot
        check the "multipass" option in your irradiance map settings.
          ARNEN
          Man , i really need some help , when i open the vray options editor it is blank i can not use it ... where do you thing it is coming from ?
          • andybotA Offline
            andybot
            um, I hate to ask, but what version of vray are you using and did you get it through official channels? If it's a legit copy, sounds like you might need to reinstall. If you're still having trouble, you could send an email to Chaos Group support for further assistance.
