    Viewport bug/glitch - extending faces?
    3 Posts 2 Posters 354 Views 2 Watching
    • saberopusS Offline
      saberopus
      Hey,
      Been having an issue for a few days now where I'll start to see weird visual artifacts where faces will appear to extend out way past their actual edges, sometimes infinitely. See below:
      http://i.imgur.com/TDqWUZU.jpg
      and here's how it ought to look:
      http://i.imgur.com/Y8OvQr9.jpg
      obviously it's happening in each instance of that component... and when I open the component for editing, it disappears. I can't select or interact w/ the apparently extending face at all.
      It's possible this has something to do w/ my graphics card... an nVidia 560 GTX Ti. I've updated the drivers (released on Sep. 18, 2014) to no effect. This skp file has 3509 edges, 1102 faces, 25 component instances, 11 groups, 10 materials. All geometry is on Layer 0. I've run thomthom's CleanUp plugin, which also didn't solve the problem.
      Any ideas? Thanks!
        Does it change if you turn off Hard Ware Acceleration in Preferences>OpenGL? You'll probably need to quit and restart SketchUp after making the change.
          saberopus
          I switched hardware acceleration off briefly and didn't notice the effect... but anyway, I started noticing a couple other weird graphical issues outside of SU, so I figured it was a graphics driver issue. I had already tried updating the driver, but this morning I did a full wipe and reinstall of it, and it seems to have worked. Thanks for your help, Dave.
