    Desperately Need help with vray (see attachment)
    renderpluginsextensions
    7 Posts 4 Posters 500 Views 4 Watching
      lilycolors
      **%(#800000)[Im using vray to do some simple interior renders. not sure why its turning out like this?
      Ive used the default sun settings (dimmed it a bit, it was too bright) and 2 rectangular lights. Please help me. what are all those grainy colors]?**
      render
        andybot
        looks to me like you have 2 copies of the model occupying the same space. All the faces appear to be overlapping. See if you can delete down to one instance of everything.
          rspierenburg
          πŸ˜† Or a bad case of termites
            lilycolors
            no, there is nothing over lapping. 😲
              andybot
              then perhaps the lighting isn't giving enough samples. Hard to say without seeing how the model is set up (light brightness, camera settings, sun location and so on.) Is this something you can post here?
                rspierenburg
                Is any of the lighting perhaps Emmissive materials?
                • V Offline
                  valerostudio
                  I second that. Currently you cannot use emissive materials as lighting (like some other engines), just lighting effect, like a TV screen. You must light your scene with omni, spot, IES, dome. rect lights. An interior like this would need a combination of these.
