    [Plugin] Smooth Zoom 2.1.0 - 24 October 2021
    76 Posts 31 Posters 86.2k Views 30 Watching
    • E Offline
      Eric5261
      I am getting an error mesage when I install the extensions and open a project.Extension Errors Report
      SketchUp: 24.0.553
      OS: Windows 11
      Ruby: 3.2.2
      Extension: SoothZoom (2.1.1a)
      Error: NoMethodError (undefined method `exists?' for File:Class)
      It gives this error on both the library and the extension. Does anyone have a solution?
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @Eric5261
        @Eric5261
        File.exists? AND File.exist? methods have worked forever. although the File.exists? method has been deprecated for along time, but someone decided to remove it completely from the Ruby version used by v2024.
        This has caused a lot of problems with code - I myself have had several files to fix for full compatibility.
        To an English speaker File.exists? is the more logical grammatically correct form, so why it changed is somewhat mysterious.
        It's a simple matter for the author to edit the files so only File.exist? is used...
        If the file is RB you could edit it to suit, but I'm sure that Anton will fix it asap...
          armerial
          I'm still waiting for this awesomeness for the 2024 version
          • F Offline
            FlorinAp
            Guys, this tool is exceptional, yet (instead of complaining about it), you should give yourself the chance to try at least for 3 weeks a Space Mouse (or 3D Mouse) from 3D Connexion.
            No opinion from YouTube (or from yourself) doesn't weigh as much as 3 weeks of day-to-day use of this device - 3 weeks is the minimum your brain needs to understand and use this device, and after that, you will ask yourself how could you ever work without it, and you will never work without it (i have 3 of them).
            This device is priceless.!
              melindasaur
              Getting an error as well:
              SketchUp: 24.0.594
              OS: Windows 10
              Ruby: 3.2.2
              Error: NoMethodError (undefined method exists?' for File:Class) C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:65:in block in require_all'
              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:63:in each' C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:63:in require_all'
              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/main.rb:95:in <top (required)>' C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in require'
              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require'
              C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom.rb:42:in register_extension'
              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom.rb:42:in <module:SmoothZoom>' C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom.rb:10:in module:AMS'
              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom.rb:9:in `<top (required)>'
              • Rich O BrienR Online
                Anton is aware of this errors. Expect a fix asap
                  Until there's a fix available, because the error is in a RB file you can edit it with a plain-text editor like Notepad++.exe
                  Find where it says File.exists? and change it to File.exist?
                  Both method coexisted for ever and were equivalent to each other, but in >=v2024 someone chose to deprecate the original correct-English sounding version, and cause authors issues.
                  After you save that edit restart SketchUp to see if that fixed it...
                  • K Offline
                    kurdoc69 @Anton_S
                    @Anton_S HELLO FRIEND, CAN YOU MAKE IT WORK ON VERSION 2025 ? IT IS MY ESSENTIAL COMPONENT ! THANK Y👏 OU
                      TIG Moderator @kurdoc69
                      @kurdoc69
                      Read my reply above yours, it outlines how to do a manual fix on the RB file, until the author responds.
                      K 1 Reply Last reply Reply Quote 0
                      • K Offline
                        kurdoc69 @TIG
                        @TIG i downloaded notepad++ but my file is rbz, when i open it i can't understand the language to edit, sorry i don't understand about this.
                          You need to install it into v2025 from the RBZ - with errors.
                          Then close SketchUp and find the RB file in your Plugins folder, open it it with Notepad++.exe and do the edit as outlined above...
                          The installed file is C:/Users/YOURUSERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb
                          • K Offline
                            kurdoc69 @TIG
                            @TIG I changed 3 places where it said File.exists? and then I get this new error
                            Informe de errores de extensión
                            SketchUp: 25.0.571
                            OS: Windows 11
                            Ruby: 3.2.2
                            Extensión: SoothZoom (2.1.1a)
                            Error: IOError (Stage directory, "C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/libraries/stage/win64/3.2", is missing!)
                            C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:76:in require_all' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main.rb:95:in <top (required)>'
                            C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in require' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in <top (required)>'
                            C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in load'
                            C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:42:in register_extension' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:42:in module:SmoothZoom'
                            C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:10:in <module:AMS>' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:9:in <top (required)>'
                              So that error seems to relate to a missing directory or file.
                              You need to wait for the author to resolve this .
                              Sorry.
                              • K Offline
                                kurdoc69 @TIG
                                @TIG thank you for your support
                                  shepyura
                                  Помогите! 2024 не работает! SOS)!ПОЖАЛУЙСТА!
                                    The earlier posts in this thread explain how to make a temporary fix by editing the RB file.
                                    В предыдущих сообщениях в этой теме объясняется, как сделать временное исправление путем редактирования файла RB.
                                    • 4 / 4
