    Spread3D
    12 Posts 4 Posters 843 Views 4 Watching
    • ntxdaveN Offline
      ntxdave
      Was wondering if anyone is using this plugin. I have not been able to install it because the Windows download does not contain a .rbz file. If there are people using the product, I would like to hear your feedback.
      Press F1...thank me later
      • ntxdaveN Offline
        ntxdave
        Lots of views but not a single comment.... 😐
        I had posted on their forum that the Windows download does not contain a .rbz file. After a send post (couple of weeks ago) they posted a message that says "under review". Nothing has happened yet though.
        Wondering is anyone is/has used the product and can give any feedback. I would like to try it but so far can not install it. ❓
          I'm not familiar with it but I did a search and found the download. It is currently downloading for me with the .rbz extension. What is the extension on the one you downloaded?
          • ntxdaveN Offline
            ntxdave
            All I got was the .zip file and then the .rb file inside. I will go try again..........
            Thanks Dave........
            • ntxdaveN Offline
              ntxdave
              Thanks Dave........
              That is what I just got again.........no .rbz file. The download gave me a .zip file. Inside it I see the .rb file and a folder that says Spread3d.ReviewPlugin but I do not see a .rbz file.
              When I tried to install it in SketchUp, here is what I see......what the heck am I doing wrong? I have tried this about a dozen times now with the same results every time. How the heck did you get a .rbz file?
              • BoxB Offline
                It's an rbz for me too. You should be able to change the zip to rbz or extract the contents into the correct plugin folder.
                Edit:I have changed the rbz to zip and extracted the contents to the plugin folder and it works perfectly.
                Where are you getting it from?
                Here? http://review.spread3d.com/getstarted#
                  As Box asked, where are you getting the file from?
                  No matter what, though, you could just change the extension from .zip to .rbz and move on. Of course it's also possible the ZIP file you've got is an older version.
                  • ntxdaveN Offline
                    ntxdave
                    Box: I got it the same place you did.
                    Dave: I had tried renaming the .zip file before and for some reason it did not work. I just tried it again and got it to work. It is now installed.
                    I really appreciate the feedback and do not understand why I do not natively see it as a .rbz file.
                    Off to try/evaluate.
                      Well, if you tried renaming before and it didn't work, I expect the contents weren't structured correctly.
                      • P Offline
                        pierrearchi32
                        Use it a lot !!!! Fantastic tool.
                        • ntxdaveN Offline
                          ntxdave
                          Thanks for the post. I am still testing. Therer are some really nice features and a couple of things I would like to see added.
                          Wish some others would chime in πŸ˜„
                          Have you tried viewing any of your presentations in IE? If so, what was the results?
                          I have one that runs OK(?) but another that always hangs on the "LOADING" screen. Both run fine in Chrome.
                          • ntxdaveN Offline
                            ntxdave
                            Since I only got one comment about the product, I thought I would post my own review. Remember, I am not a SU power house so my views may be tainted.
                            I like Spread3D and think it is a good product. The price is certainly affordable. The "Pro" version is only $5/month. There is a free version but your presentations are only viewable for 24hours.
                            Strengths
                            • Easy to learn - The UI for Spread3D makes it very easy to learn. There are a number of tutorials that seem to cover all of the capabilities pretty thoroughly.
                            • Play/Autoplay - Spread3D allows you to play/autoplay your presentation so that it is good for a kiosk type of environment or if you want to display your presentation in an unattended mode. There are settings for the slide duration and transition speeds. * Hierarchy - Spread3D gives you full access to the hierarchy in your model that can be manipulated at the slide level. Thus you can control the visibility or some limited animation of a group or component in he model at the slide level. Certainly strengthens the concept of using groups and components in your model in SU.* Links to external documents and videos - While I did have not yet used this feature, Spread3D allows you to connect to other documents and videos outside your model. You can also create links to external web sites. * Comments - Again, I have not used this feature (but I did look at it) that provides the capability to allow others to add comments about your model or presentation.* Rotate/Zoom/Pan/Measurements - You can add buttons to a slide that will allow the user to rotate, zoom, pan and even use a ruler on the slide. This again, is controllable at the slide level.* Auto Rotate- You can create a slide that will automatically rotate when the slide is viewed.
                            Weaknesses
                            Only One Model per Presentation - For me one of the biggest weaknesses it that you can only have one SU fie/model in a presentation. Therefore, if you want to have multiple models included in a presentation you must combine them into a single SU file and scene (you cannot export multiple SU scenes into a single presentation. If you combine models into a single file, you can overcome this limitation somewhat by using the hierarchy to control what is visible on the slide but this could get messy in a hurry* Fonts & Text display - Currently there is a limited set of fonts that can be used in a Spread3D presentation. There are also some limitations on how the text is controlled on the slide (how it appears, color and etc.). However, I have been told that this is being addressed in a future release (no timing on the update). One interesting thing I did discover though is the ability to create a scrolling list/text box.* Performance in IE - One of my presentations would never load in IE. All of my presentation did run smoothly in Chrome (I have only tested with IE 11 and Chrome). Since most of our clients use IE, this could be a problem in making our presentations available via our web site. For a show/convention we can make sure the machines being used have Chrome installed.* No Touch Screen Support - While this is not a show stopper, it is preferred for a show/convention so that the presentations can be used in a kiosk type of environment without having to have a mouse connected.
                            Bottom Line
                            Bottom line is that this is a good product that is VERY reasonably priced. It has a lot of good basic features and I have no problem recommending it. Just be aware of the one SU file limitation and you should be able to learn/use it in a very short time. The documentation is very adequate to get you going quickly.
