    Undo function isn't working properly
    2 Posts 2 Posters 391 Views 2 Watching
    • D
      Dutchmeikuh
      Hello, last 3/4 months I didn't have the time to draw something. Finally I found some time and then, I discovered a weird problem with the Undo function. I think most people would use the normal CTRL + Z configuration like I do, but SU won't save this setting. Alt + Backspace is everytime the 1st shortcut, when I change it to CTRL + Z, next time it's gone and back like it was..
      That's problem one.
      Problem 2 is that my Undo function won't go back that far like I was used to. I think it was up to 100 steps back when you press CTRL + Z constantly? Really nice working that was. Now it's sometimes 1, 2 or maybe, when I'm lucky, 5 steps back. It's driving me crazy... this isn't working at all.
      There's something wrong with my memory, chache or something that I have poblems like this? Or something else?
      Edit ;
      I think the problem is a little bit bigger then the Undo Function alone.
      I just started a render, settings for reflections and so, but nothing changed. very material I editted with some render settings, SU didn't save them at all.
      I've used a photoshop-liked programm. I drew 20+lines or so and there I didn't had the problems I have in SU. I just can go back to the fist line I drew with the undo function.
      Has SU his own cache memory? What can I do to eliminate this problem?
      So, this is a memory/cache problem for sure, I think. The only thing SU have saved and is staying 'normal' as I've wanted, are my toolbar settings.
        I seem to recall there was a plugin that commandeered the Undo function somehow. I'm thinking it was an older version of Jiminy-Billy-Bob's Layers Panel. If you've got it and haven't updated it, try that.
        As for your rendering issues, what rendering application are you referring to? You refer to reflections so that can't be native SketchUp.
