    What is the right way to model for "vray for sketchup"?
    renderpluginsextensions
    2 Posts 2 Posters 349 Views 2 Watching
      samifox
      my first post here,
      i want to make an exterior and interior rendering of 2 floor villa,
      i wonder what is the right way to model the structure so i wont face artifacts later when im in the interior scenes,
      do i need to extrude the walls from the floor or its ok to make the floor first,group it, and than the walls, group it and follow up?
      Shay
      • TedVitale_CGT Offline
        TedVitale_CG
        I always suggest modeling how it would actually be constructed to get the best results. If you have a concrete floor slab ant the walls are attached to it, then model it like that. Groups are your friends and so are components. Also make sure all of your faces are oriented correctly so that you don't run into problems with back faces facing outward. Really, there's no wrong way to model in Sketchup for V-Ray, there are just more and less efficient ways to work.
        If you share your model here I would be happy to take a look and give you some more tips!
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
