    How does one make an open umbrella?
    9 Posts 4 Posters 1.3k Views 4 Watching
    • K Offline
      k_drive
      I am trying to make an open umbrella. I am having difficulty making the scalloped part of the fabric where it dips in between the ribs as it curves to follow the shape of the ribs.
      I have tried to make a basic "U" shape and then extrude it out over a curve making the shape wider as I pull it out bit by bit. But, that doesn't work very well.
      If I could get one section in between the ribs, it would be easy to rotate and repeat. The shape has to have the dip in it as it curves downward.
      So, I need to know how to do two things:
      1. Make a "U" shape that is wide on one end and small on the other end.
      2. Make this shape follow a curve as it changes in size.
      Reference images:
      http://www.londonundercover.co.uk/shop/umbrellas
        Maybe something like this! Take a sub multiple of 360Β° for the red arc! (profil) πŸ˜„
        Extrude tools by Tig
        And make after some copy rotations! πŸ€“
        Of course you can use 2,3, or 4 curves maxi and any form of curves, inversed, sinusoΓ―ds etc...
        better and speeder if curves 2 by 2 (rails) have same number of seggments! πŸ€“
        Maybe recurve by Digssey can help you if you wand weld some explosed curves!
        And funny thing with Random Painter by Chris Fullmer!
        I am not sure that his marvelous plugin works with the 2014 ? πŸ˜’
        • ely862meE Offline
          ely862me
          Indeed, what Pilou offered is the easiest way, but you can make it with the regular tools too.
          Umbrella-EliseiDesign.skp
          Elisei (sketchupper)
          Come and See EliseiDesign
            If you choose to use Extrude Edges by Rails, you'll need to make the shape correctly with an inward-curving arc for the edge of the fabric.
            • K Offline
              k_drive
              Thank you very much, Dave R. I will look into this plug-in. It looks like it could be useful for a lot of things.
              K
              • K Offline
                k_drive
                Thank you very much, ely862me. This looks like a good solution with just the basic tools. I will give it a try. I just couldn't figure out how to do the dip/scallop in the sections.
                K
                  And then erase all that you don't want! πŸ˜‰
                  PS For select the circle
                  Double click on the surface on the disc, then click with Shift + Ctrl on the disc
                  For erase the corner : click on it with
                    Pilou, how does that create the scalloped edge at the bottom between the ribs?
                      Easy πŸ˜„ And without plugin πŸ˜‰
                      Just kill the 2 little white edges and disc surface and all the no wanted at the end!
