    Is there a plugin to slice an object along a cutting plane?
    29 Posts 9 Posters 5.4k Views 9 Watching
    • falkF Offline
      falk
      OK, that was pretty impressive. It's pretty much how I've been doing it; you're just better at it than I am. You should post this under "tutorials"
      Oh, I also see how using a cutting rectangle instead of a section plane also automagically healed the faces. Very nice.
      • sdmitchS Offline
        sdmitch
        Is this what you were looking for.
        http://sdmitch.blogspot.com/
          Thanks.
          It does if and only if the cutting surface is in the same context as the faces being cut. You're just leaving some of the cutting surface behind to be the face skinning the openings. The cutting surface doesn't need to be a flat face, either. So the pommels on these columns as well as the tops of the reeds were done essentially the same way.
          https://farm6.staticflickr.com/5568/14695628286_768c95bff6.jpg
          As were the stopped chamfers on the stretchers for this hayrake table.
          https://farm6.staticflickr.com/5133/5484028186_e75a00b16a.jpg
          And the stopped flutes on this newel post...
          https://farm9.staticflickr.com/8530/8511785423_9b3ca804d5.jpg
          .. and the cope joints on the rails of this door.
          https://farm9.staticflickr.com/8212/8321018421_692f410d95.jpg
          And you can't do any of those with a section plane.
          • falkF Offline
            falk
            Yes, exactly. It even healed the faces. Checking out SDM tools now.
            • falkF Offline
              falk
              @dave r said:
              ... So the pommels on these columns as well as the tops of the reeds were done essentially the same way.
              OK, now you're just showing off πŸ˜„
              I've never done anything as nice as those images, but yeah, I've been using this technique for years. I was just looking for something faster for straight cuts.
                Not trying to show off. Just trying to show examples. Anyone can do this stuff.
                • falkF Offline
                  falk
                  I found lots of cool plugins at http://sdmitch.blogspot.com/, but I couldn't find this one. Is it published yet?
                  • sdmitchS Offline
                    sdmitch
                    No but I have sent it to you by PM.
                    • falkF Offline
                      falk
                      Got it. It's awesome. Thanks! It's exactly what I had in mind. I'm going to put this to good use.
                      • 2 / 2
