    Is there a plugin to slice an object along a cutting plane?
    29 Posts 9 Posters 6.4k Views 9 Watching
    • falkF
      falk
      OK, just as an experiment, I tried my example using this technique. With a horizontal section plane, it took me 45 seconds to split my model in two. With a section plane at 45 degrees, it took 90 seconds. I'm sure with practice I could bring those times down.
      I use SU for woodworking mainly. My design process is to design the object I want to build, then slice it into boards I could cut on a table saw. This involves a lot of slicing, so if I could automate the process that would be a win. I'm definitely going to put a little bit of time into tinkering with Zorro2.
      • falkF
        falk
        @dave r said:
        Understood. I'll put my tutorial πŸ‘ on hold then.
        Don't do that. It will probably help me and it will definitely help other people.
        • BoxB
          Tig's slicer would help, and it isn't pro only.
            OK. Here it is although it's a bit sloppy. Nothing but native tools used throughout. I started assuming you'd already have the component or group made and want to split it.
            The reason you have to trace edges to heal faces is because you don't have the cutting plane in the same context as the geometry you're cutting. I start out with the cutting plane outside the component but move it inside the component before intersecting. Then both the geometry in the component as well as the component get the intersections so the faces are created.
            The other key things are proper use of the Selection tool, the use of keyboard shortcuts and the use of Edit>Paste in place.
            • falkF
              falk
              OK, that was pretty impressive. It's pretty much how I've been doing it; you're just better at it than I am. You should post this under "tutorials"
              Oh, I also see how using a cutting rectangle instead of a section plane also automagically healed the faces. Very nice.
              • sdmitchS
                sdmitch
                Is this what you were looking for.
                http://sdmitch.blogspot.com/
                  Thanks.
                  It does if and only if the cutting surface is in the same context as the faces being cut. You're just leaving some of the cutting surface behind to be the face skinning the openings. The cutting surface doesn't need to be a flat face, either. So the pommels on these columns as well as the tops of the reeds were done essentially the same way.
                  https://farm6.staticflickr.com/5568/14695628286_768c95bff6.jpg
                  As were the stopped chamfers on the stretchers for this hayrake table.
                  https://farm6.staticflickr.com/5133/5484028186_e75a00b16a.jpg
                  And the stopped flutes on this newel post...
                  https://farm9.staticflickr.com/8530/8511785423_9b3ca804d5.jpg
                  .. and the cope joints on the rails of this door.
                  https://farm9.staticflickr.com/8212/8321018421_692f410d95.jpg
                  And you can't do any of those with a section plane.
                  • falkF
                    falk
                    Yes, exactly. It even healed the faces. Checking out SDM tools now.
                    • falkF
                      falk
                      @dave r said:
                      ... So the pommels on these columns as well as the tops of the reeds were done essentially the same way.
                      OK, now you're just showing off πŸ˜„
                      I've never done anything as nice as those images, but yeah, I've been using this technique for years. I was just looking for something faster for straight cuts.
                        Not trying to show off. Just trying to show examples. Anyone can do this stuff.
                        • falkF
                          falk
                          I found lots of cool plugins at http://sdmitch.blogspot.com/, but I couldn't find this one. Is it published yet?
                          • sdmitchS
                            sdmitch
                            No but I have sent it to you by PM.
                            • falkF
                              falk
                              Got it. It's awesome. Thanks! It's exactly what I had in mind. I'm going to put this to good use.
                              • 2 / 2
