    Is there a plugin to slice an object along a cutting plane?
    29 Posts 9 Posters 6.0k Views 9 Watching
    • falkF
      falk
      @dave r said:
      Understood. I'll put my tutorial πŸ‘ on hold then.
      Don't do that. It will probably help me and it will definitely help other people.
      • BoxB
        Tig's slicer would help, and it isn't pro only.
          OK. Here it is although it's a bit sloppy. Nothing but native tools used throughout. I started assuming you'd already have the component or group made and want to split it.
          The reason you have to trace edges to heal faces is because you don't have the cutting plane in the same context as the geometry you're cutting. I start out with the cutting plane outside the component but move it inside the component before intersecting. Then both the geometry in the component as well as the component get the intersections so the faces are created.
          The other key things are proper use of the Selection tool, the use of keyboard shortcuts and the use of Edit>Paste in place.
          • falkF
            falk
            OK, that was pretty impressive. It's pretty much how I've been doing it; you're just better at it than I am. You should post this under "tutorials"
            Oh, I also see how using a cutting rectangle instead of a section plane also automagically healed the faces. Very nice.
            • sdmitchS
              sdmitch
              Is this what you were looking for.
              http://sdmitch.blogspot.com/
                Thanks.
                It does if and only if the cutting surface is in the same context as the faces being cut. You're just leaving some of the cutting surface behind to be the face skinning the openings. The cutting surface doesn't need to be a flat face, either. So the pommels on these columns as well as the tops of the reeds were done essentially the same way.
                https://farm6.staticflickr.com/5568/14695628286_768c95bff6.jpg
                As were the stopped chamfers on the stretchers for this hayrake table.
                https://farm6.staticflickr.com/5133/5484028186_e75a00b16a.jpg
                And the stopped flutes on this newel post...
                https://farm9.staticflickr.com/8530/8511785423_9b3ca804d5.jpg
                .. and the cope joints on the rails of this door.
                https://farm9.staticflickr.com/8212/8321018421_692f410d95.jpg
                And you can't do any of those with a section plane.
                • falkF
                  falk
                  Yes, exactly. It even healed the faces. Checking out SDM tools now.
                  • falkF
                    falk
                    @dave r said:
                    ... So the pommels on these columns as well as the tops of the reeds were done essentially the same way.
                    OK, now you're just showing off πŸ˜„
                    I've never done anything as nice as those images, but yeah, I've been using this technique for years. I was just looking for something faster for straight cuts.
                      Not trying to show off. Just trying to show examples. Anyone can do this stuff.
                      • falkF
                        falk
                        I found lots of cool plugins at http://sdmitch.blogspot.com/, but I couldn't find this one. Is it published yet?
                        • sdmitchS
                          sdmitch
                          No but I have sent it to you by PM.
                          • falkF
                            falk
                            Got it. It's awesome. Thanks! It's exactly what I had in mind. I'm going to put this to good use.
                            • 2 / 2
