    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Помогите разобраться в Round Сorner
    9 Posts 2 Posters 242 Views 2 Watching
      Sharlotta
      Здравствуйте, я новичек в sketchup, помогите, пожалуйста разобраться, у меня проблема с плагином round corner при выборе линий у меня получается так:
      https://e.mail.ru/attaches-viewer/?x-email=yulia.te%40mail.ru&offset=0%3B1&id=14087727930000000454&_av=14087727930000000454%3B0%3B1
      при подтверждении получается непонятная фигура:
      https://e.mail.ru/attaches-viewer/?x-email=yulia.te%40mail.ru&offset=0%3B1&id=14087729030000000990&_av=14087729030000000990%3B0%3B1
      Скажите пожалуйста, что я не так делаю, заранее спасибо.
      • massimoM Offline
        massimo Moderator
        Hi, please use english here on the forum. Also your images are not visible. Use the "upload attachment" feature you'll find at the bottom of the "reply" page, so the images will be loaded directly here.
          Sharlotta
          Hello, I'm new to SketchUp, please help me to understand, I have a problem with the plugin round corner when choosing lines I get this: picture 1
          when confirmation is obtained incomprehensible figure: picture 2
          Please tell me, what am I doing wrong, thanks in advance.
          • massimoM Offline
            massimo Moderator
            The offset seems too big for the model you have. Reduce it.
              Sharlotta
              Thank you very much for your help!
              • massimoM Offline
                massimo Moderator
                You're welcome. 😄
                  Sharlotta
                  Please tell me how to remove the pop-strips?
                  • massimoM Offline
                    massimo Moderator
                    If you mean in "RoundCorner" plugin, be sure that both "borders" and "inner edges" are set to "soft" only.
                    Anyway you can of course do triple click-->right click-->soften/smooth edges at the end.
                      Sharlotta
                      Thank you, thank you very much 👍
