    Reflection layers not working on any material
    renderpluginsextensions
    3 Posts 3 Posters 519 Views 3 Watching
    • B
      bitslapped
      Hi there seems to be a problem when adding reflection layer to a material.
      Once I add the layer, the preview just goes black, and the render comes out empty.
      This is the same whether I add it manually or import a material with existing reflection layer. It doesn't happen for refraction.
      I managed to get it to work once without much thought but have since found it impossible.
      Any suggestions on what might be the problem?
      Thanks heaps.
      • TedVitale_CGT
        TedVitale_CG
        You can also contact V-Ray support with this issue at support@chaosgroup.com
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
        • chonC
          chon
          which version of SU, which version of VrayForSU, any screenshots of the material panel ?
          SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
