    Layout Hybrid rendering inaccurately
    layout
    2 Posts 2 Posters 657 Views 2 Watching
    • T
      tcalvin
      I'm having rendering problems in Layout. When I render a drawing in Hybrid mode it shows different modeled items in what looks like a wireframe mode on some parts of the drawing. Not all Items get rendered in this "see thru" view but for the most part it seems ok. For example I've rendered a Plan View Scene that includes a bathtub brought in from 3D Warehouse. The Scene is originally saved in a Textured view. When the SU view is inserted into a LO page the tub is seen as if it's transparent and you see the lines that create the feet (for example) thru the body. I can't figure this out why it occurs. Anyone have a clue??
      I can provide the LO and SU file if someone wants to check it out.
        I know this will sound strange but go into the presences window in SketchUp and chane the OpenGL settings. Try turning Hardware accretion off. Quit and reopen LayOut. Then rerender the viewport and see if it fixes the problem.
