Extruding a face from a contoured terrain?
Im wondering if there is a plugin/tool that allows me to extrude a contoured (non flat) face from a terrain.
Currently I am using a line extrude command, then copying up the face to that height.
Or I am intersecting a 'flat' extruded face between to levels of the contoured terrain. These are very time consuming. (hope this makes sense)
Anything out there?
Fredo's Interactive joint push pull.
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=54771#p496773 -
Yeah, Fredo's Joint Push Pull for sure. Its a must have plugin.
If you are doing this a lot and selecting smaller portions of a bigger landscape, you might also want to get better seletion tools, like a lasso tool, to cut down on selection time. Thomthom's Vertex Tools has a nice variety of selection tools.
Anything out there?
Perhaps this plugin?
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=48812%26amp;hilit=+curves
A sample model showing what you start and end with would be most helpful.
Register LoginAdvertisement
